Camshaft sensor location
the camshaft position sensors are between the firewall and back of the motor.
One is below the throttle body and the other is below that PCV valve iirc.
There are two, one on each side and they are not interchangeable. they are held on by 1 10mm bolt each. The one on the passenger side takes literally 10 min to swap and the one on the driver side requires removal of the tb and takes upwards an hour to do. Dont let the dealer rip you off on labor charges.
If you need replacement sensors call the guys at mynismo.com 's factory parts division. I was able to buy and 2 day air a cam position sensor cheaper then buying local.
what code are you throwing?
Tochigi_236
Sep 27, 2015 03:40 PM
