Need help!! Engine is on but RPM won't go up
Old Oct 6, 2008 | 09:12 AM
chrisnathan's Avatar
chrisnathan
Unhappy Need help!! Engine is on but RPM won't go up
Guys,
I need help. I can start up my engine but the RPM just stays at 1.5k even I press the accel. pedal all the way to the floor. Anyone knows what's going on?
I only have some light mods on my car. All the lights are on, SES, VDC and SLIP, damn, wtf happened? And after so much reading, there is no exact answer to this.
I cleaned the MAF and throttle body and worked like magic last night. But this morning when I was about to go to work, it acting up again. Gosh, I might try the fuel injector cleaner thing later when I get home, but that might be my last resort before I take it to the stealership.
Any expert advice? Anyone experienced this before? HELP!! PLEASE....
Old Oct 6, 2008 | 09:38 AM
gothchick's Avatar
gothchick
You can hear the engingine rev, but the tack isn't moving? = bad tach.
Or
The engine wont rev past 1.5? = Limp mode.
Old Oct 6, 2008 | 10:31 AM
chrisnathan
Or
I think it is the Limp mode, engine won't rev past 1.5, anyone know how to solve this problem?
Old Oct 6, 2008 | 08:35 PM
Spork's Avatar
Spork
Try reset the ecu by either using the procedure or disconnecting your battery for 20 minutes.
Old Oct 6, 2008 | 08:42 PM
lay zzz's Avatar
lay zzz
happened to me..i dont think its the reset..i went to the shop it was the throttlebody sendor..drive by wire is bad
Old Oct 6, 2008 | 08:46 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
But car is moving tho?
Old Oct 7, 2008 | 05:41 AM
gothchick's Avatar
gothchick
Any CEL codes?
Old Oct 7, 2008 | 07:18 AM
importpunisher's Avatar
importpunisher
maybe the battery went bad, is it a stock one? my car acted funny when the battery went out.
Old Oct 7, 2008 | 09:14 AM
jutnismo350z's Avatar
jutnismo350z
Dreamz n Motion
i had the same problem when i installed my Cold Air intake back when i purchased it. I replaced my Mass Air Flow Sensor and it never happened again.
Hate to say it, but u probably need a new mass air flow sensor
Old Oct 7, 2008 | 09:49 AM
Chef-J's Avatar
Chef-J
Booooosstt!!
^ if it is, there is guy selling his MAF, check that out. Here
http://g35driver.com/forums/engine-f...af-sensor.html
Old Oct 7, 2008 | 10:05 AM
SpoilsofWar's Avatar
SpoilsofWar
+1 on limp mode, it should be throwing a code to tell you whats up.
Even if the SES light isnt on, you should scan to see if any codes are pending.
Old Oct 7, 2008 | 12:03 PM
maestro1991's Avatar
maestro1991
Default RE:
Had the exact same thing happen. Still fighting with dealership over it. They replaced the ECM, alternator - turned out to be bad oxygen sensor. Check if any wires are damaged, mine were chewed by some animal.
Old Oct 7, 2008 | 04:01 PM
superchargedg's Avatar
superchargedg
Damn Noobs
Sounds like na bad throttle body.
Old Oct 7, 2008 | 06:44 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
Any update?
Old Oct 7, 2008 | 06:58 PM
chrisnathan
Well, update: I replaced the spark plugs w/ NGK Iridium, cleaned the MAF and TB, tighten spacer bolts, disconnected the battery while doing all those stuff. Turned on the engine and everything was good. Took me 5 hours to work on those w/ a help from my brother.
BUT, this afternoon when I dropped off some package I have to send out, the freakin same thing happened, all the lights on and engine won't let me rev beyond 1.5k. Turned off the engine and started it again, gone, but the SES light on this time instead of everything.
What a crazy motherf***er, I have no idea now. Do you guys think it is the MAF or TB problem? I reset the SES lights like 20 times so far, I'll bring it to Autozone the next time it comes out. Any input?
Old Oct 7, 2008 | 07:00 PM
chrisnathan
Were you able to clean and worked temporarily before you replace them?
Old Oct 7, 2008 | 07:02 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
I will just go stop by autozone, even it won't throw SES or CEL light. Worthy it to try for in your situation.
Old Oct 7, 2008 | 07:05 PM
chrisnathan
Originally Posted by xhooniex83
I will just go stop by autozone, even it won't throw SES or CEL light. Worthy it to try for your situation.
Yes, I'm doing it tomorrow, dealership might my very last resort. Enough bad stories I heard.
Old Oct 7, 2008 | 07:08 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
Why don't you take it to performance nissan or Edit: west covina nissan? are they far from you?
Old Oct 7, 2008 | 07:32 PM
chrisnathan
^^ They are kind of far, besides the fact I gotta work from 8 to 7 Mon-Fri.
