VDC, SLIP, BRAKE light all on???
Old Oct 16, 2008 | 10:42 AM
b00b00's Avatar
b00b00
Default VDC, SLIP, BRAKE light all on???
Well I noticed my VDC, SLIP and BRAKE light come on, and off when I start the car.
Has this ever happened to any of you guys???
It comes on and off....all 3 of them come on together.
Sorry if this is in the wrong section.
its a 2003 if it helps.
Old Oct 16, 2008 | 10:55 AM
PRuane's Avatar
PRuane
Do they turn on and stay on? Or turn on when you turn the key, then turn off immediately after?
Old Oct 16, 2008 | 11:01 AM
b00b00's Avatar
b00b00
Once there on, they stay on, but sometimes when i do start the car, they dont come one....
its more of a 50/50 thing, when I start it.
They dont flicker or anything when there on.
Old Oct 16, 2008 | 01:08 PM
KAZ350Z's Avatar
KAZ350Z
Check the MAF sensor plugged into your intake. It sounds like a bad connection. If that's unplugged and you start the car all the lights turn on. Not sure if that's the problem, but it's definitely a possibility. And make sure you disconnect the battery before you try again to reset everything.
Old Oct 16, 2008 | 02:18 PM
denverinfiniti's Avatar
denverinfiniti
Check your brakes and brake fluid. Sounds like the fluid is low from your brakes being worn out
Old Oct 16, 2008 | 02:28 PM
b00b00's Avatar
b00b00
Ill check all those.
BUT
When the lights are on, my VDC dosent even work. If the lights are not on, then the VDC does work.
Can it do somehting with my DIFF??
Old Oct 16, 2008 | 04:54 PM
Spike100's Avatar
Spike100
BUT
You will need to provide a much better "problem description" if you hope to get any help here. Reading your thread, I am unable to understand the problem.
"Start over," and provide a more detailed description of the problem.
--Spike
Old Oct 16, 2008 | 06:53 PM
b00b00's Avatar
b00b00
Sorry about that, Im always in a rush, kinda like now.
Ok When I start my car, my VDC, SLIP and BRAKE light all come on at once, and stay on.
Sometimes it dosen't come on.
Well since all those lights are on my VDC dosent work, and when they dont come on, my VDC works.
Hope I said it better, if not, damn I suck at explaining things
Old Oct 16, 2008 | 06:54 PM
b00b00's Avatar
b00b00
And also when I push the VDC button, they still dont shut off or anything.
Old Oct 16, 2008 | 07:01 PM
RMichael's Avatar
RMichael
brake fluid level or time for a pad change.
Old Oct 16, 2008 | 11:12 PM
b00b00's Avatar
b00b00
That would cause the VDC not to work??
Old Oct 16, 2008 | 11:23 PM
stealthz's Avatar
stealthz
answer is yes.... in most cases it is the brake fluid is a low or pads
Old Oct 17, 2008 | 03:02 AM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
That could be a number of things. I doubt brake fluid or pads typically just the brake light will come on. It sounds like a throttle body or a crank sensor take it somewhere and get it scanned.
Old Oct 17, 2008 | 09:25 AM
foreignsoda's Avatar
foreignsoda
when that happened to me, it was an electrical problem. my radar detector cord was not inserted all the way (i tap into the back of my rearview mirror for power). pushed it in and all was fine. have you installed any electrical components lately?
Old Oct 17, 2008 | 11:04 AM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
My brake fluid got low due to pad wear last year and my brake light would come on under hard accel or hard braking for about a month. I didn't think too much of it until I had my SLIP, VDC off, and BRAKE lights all come on at the same time and then VDC and my ABS didn't work. As soon as I added a little fluid, the problem went away.
So yes, the fluid level CAN affect the VDC system.
Old Oct 17, 2008 | 02:50 PM
b00b00's Avatar
b00b00
Im going to check that today! if i have time
But serious mine started out that way to....It would be off, then I would give it gas then it would come one right when i shifted gears!!
Old Oct 19, 2008 | 03:47 PM
Spike100's Avatar
Spike100
I agree with BriGuyMax. The stability part of VDC operates by tapping the car's brakes when re-aligning to the front wheels in a skid. If the computer detects any brake problems, it disables VDC (thank goodness).
--Spike
Old Oct 19, 2008 | 05:45 PM
stealthz's Avatar
stealthz
In the order of the repairs checking the fluid would be first in the number of things to check, because yes even though you doubt it all those lights do come on with low brake fluid, even more so when the fluid is colder....
Old Oct 19, 2008 | 05:50 PM
m3inaz's Avatar
m3inaz
Go get some brake fluid, I know 4 people that had this problem including me, just put some fluid in.
Old Oct 28, 2008 | 01:41 PM
dnguyent's Avatar
dnguyent
I have this problem too. My ABS/SLIP/TCS lights went on immediately after turning the car on. It all started on the track when I wore my pads down to 2mm, and my fluid levels were lower than usual; 'Lower' being that it was still well within the low/max level, but not near 'max' where I usually have it.
In any case, I topped it off, installed new pads, and I still get intermittent malfunction of the ABS/SLIP/TCS. I'm thinking that the brake fluid level sensor is now bad because it has lost its calibration, and is no longer able to sense that there is enough fluid in there.
I've nearly eliminated the potential for bad wheel speed sensors because when those go bad, they usually trigger the ABS/SLIP/TCS lights after driving for a minute or so; not immediately upon twist of the key.
Anybody have a DIY fix for this problem?
