trasmission ? on a 07
Old Oct 20, 2008 | 09:58 PM
hellsoldiers08's Avatar
hellsoldiers08
Unhappy trasmission ? on a 07
So one day when i was cruising around 40 i needed to down shift to get some more speed. Well i felt and kinda heard a grinding noise when shifting down to 5th gear from 6th. I thought maybe i didnt push down all the way on the clutch, so yesterday it came up again and as soon as i heard it i checked to see if the clutch was fully pressed down,which it was. I then went back to 6th gear and then i put the gear in 5th and in the half way area it made the sound again. So should i get this checked out at the dealer? I mean it happens every blue moon but should i be worried???
Old Oct 21, 2008 | 06:48 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Your transmission should not grind between gears if you are shifting properly. I would take it to the dealer and have them check it out. Good luck.
forgedZ
May 18, 2009 07:02 AM
