serious issues need help!
Old Oct 27, 2008 | 04:21 PM
blackwolf1778's Avatar
blackwolf1778
Default serious issues need help!
well i got a few problems and i need some help
car has 32K miles and is a 2003 touring
has the anoying throw bearing noise or what ever its called but has got worse over the past 6K miles and now seems like it grabs or somthing because it effects the RPMS when idleing at 800 or so it will flex between 600-800 acting like it wants to die
when speeding up in 4th 5th or 6th i get like clutch slip but in 1st-3rd i cant get it to slip if i try (even downshifting hard) ((started in the past 800 miles))
when cold start and get on it my oil preasure will almost peek but shortly after warm up its normal (never did that until the oil change) ((checked oil level 3 times a week to make sure im not to high or low))
any responces will help thanks alot
Old Oct 27, 2008 | 04:44 PM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
oil thing is pretty normal most likely due to weather change and sounds like you need to plan on doing your clutch soon.
350z82
Oct 1, 2015 06:25 PM
