Auto trans guys.... HELP!!!
Old Dec 14, 2008 | 11:15 AM
niceguyyy01's Avatar
niceguyyy01
Default Auto trans guys.... HELP!!!
Got a built trans and I cannot get the trans to go into park. The shift rod is about 1/2-3/4" too short to reach the rod that comes down from the shifter. I can even still rotate the driveshaft with the trans in (what I believe should be) park. Is that normal? Does this trans need power and fluid to lock into park? I believe I have a problem though, because the shifter rod should still reach the shifter and it doesnt. Can anyone help me?
Old Dec 14, 2008 | 05:19 PM
niceguyyy01
I was able to read the service manual and pull the VB and fix it.
Old Dec 14, 2008 | 05:40 PM
niceguyyy01
Well for anyone following this here is what I posted on my thread on G35.
Ok guys.... believe it or not I figured out the problem and was able to fix it. Here is a pic I took before I fixed it. If you notice the stud on the shift arm is not inside the plunger. I was able to take loose the plunger and get the stud back in the lunger seat and WHALAAA, the trans goes into park and works like it should. But I will say this, the trans showed up on my door like this, which tells me the previous owner must have had issues with it.
Old Dec 14, 2008 | 06:15 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
Yep, I almost did that.
Old Dec 15, 2008 | 03:42 PM
superchargedg's Avatar
superchargedg
Damn Noobs
You are not the only one either.
burglapfd
Dec 6, 2020 01:04 PM
Jambo016
Sep 16, 2016 01:08 PM
_bit
Oct 2, 2015 07:49 AM
