Bolts for plenum
Old Dec 27, 2008 | 08:44 PM
autodrifter4's Avatar
autodrifter4
Default Bolts for plenum
Im removing my plenum spacer sometime next week but i lost my old bolts for the stock plenum. I was wondering if you guys knew what sizes they were so i can go pick them up at a hardware store of if you guys had the bolts
thanks for the help
Old Dec 27, 2008 | 10:51 PM
mthreat's Avatar
mthreat
I'd suggest going to your Nissan dealer where they can pull up the parts diagram so you can get the exact correct parts.
Old Dec 27, 2008 | 11:26 PM
JETPILOT's Avatar
JETPILOT
These are per the Nissan Service manual. They should be available at any auto parts store.
M6 X 25mm bolt w flange(9)
M6 X 45mm bolt w flange(3)
M6 X 60mm bolt w flange (4)
M6 nut w flange (2)
Old Dec 28, 2008 | 08:09 PM
autodrifter4
thanks Jet!
would you happen to know where each ones goes?
I know the 60mm bolts go in the center rear of the plenum (it says 4 but there are only 3 places to put them)
then 25mm bolts go around the plenum and the 3 45mm bolts go in the center front of the plenum.
What is the M6 nut with flange for and what does the extra 60mm bolt go?
Old Dec 29, 2008 | 06:55 AM
pmohr's Avatar
pmohr
Originally Posted by autodrifter4
thanks Jet!
The two nuts are for the guide studs that are in the lower plenum.
Old Dec 29, 2008 | 09:10 AM
Escobar's Avatar
Escobar
how the hell did you lose your bolts?
AbrasiveRaysive
Sep 20, 2021 02:29 PM
wanderingstuden
Jan 28, 2016 07:03 PM
