grinding on 3rd gear
Old Aug 30, 2003 | 04:28 AM
iklim's Avatar
iklim
Default grinding on 3rd gear
is it just my car that grinds on 3rd?
it seems to grind once in a while..
it only grinds on 3rd..
well..
its getting more often
should i go to dealer?
i think they will say 'could not duplicate (problem)" since it doesnt happen all the time..
any suggestions?
it grinds even when the clutch is fully depressed..
well..
when it doesnt grind, it doesnt though clutch is not fully depressed.
so i guess fully depressing the clutch isnt the problem..
help me out plz!~~~
Old Aug 30, 2003 | 05:08 AM
dwnshift's Avatar
dwnshift
Yes there is synchro proble with the first two genrations of this gear box.
Our first souple of race we were rebuilding the transmission befoer every race weekend. We received updates for the gearbox which helped out teh 5/6 shift fork issue but we were still having a grind
And if you guys thought yours was bad on the street..imagine what it was like in a race application......
We have also had the best luck with Mobil One syn gear oil...
We then received vesion three which has all new internals and have had (knock on wood) very good luck with it as its held up the last two race weekends.
Old Aug 30, 2003 | 05:26 AM
Michael Riiehl's Avatar
Michael Riiehl
Had this problem exactly, the mechanic at my dealership was well aware of the issue as Nissan has already made note in technical reports. New Transmission ordered and installed with no hassle and has completely corrected the grind. This is a well known issue to all (do Search).
Old Aug 30, 2003 | 07:32 AM
03daytonablue's Avatar
03daytonablue
Default 3rd gear grind
Im also having this very same problem with the clutch pedal fully pressed shifting into 3rd it will grind every once and a while. I was worried about taking it in but if they have a third update now I think it is time.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
sherm
Apr 11, 2020 05:21 PM
kyin
Oct 15, 2015 05:54 AM
Conway_160
Drag
Sep 29, 2015 08:07 AM
Ace2347
Sep 22, 2015 03:12 AM
