Rev-up: WHP w/ 5/16th,Mrev2,JWT s7 cams,Borla TD, reflash?
Old Jan 28, 2009 | 01:39 PM
kacz07's Avatar
kacz07
Default Rev-up: WHP w/ 5/16th,Mrev2,JWT s7 cams,Borla TD, reflash?
Mods please delete!!!
Old Jan 28, 2009 | 01:45 PM
cdoxp800's Avatar
cdoxp800
I'll go about 270 whp.
How about you go get a Dyno
Old Jan 28, 2009 | 01:49 PM
n1sm0r's Avatar
n1sm0r
I'd say 270whp if you added test pipes to the list, but every car is different, and ricer math is never right. Just dyno
Old Jan 28, 2009 | 01:50 PM
kacz07's Avatar
kacz07
do not have parts installed
do not have cams
do not have funds for dyno tuning yet
Dang. I want 280. Can't you lie to me?
Old Jan 28, 2009 | 01:51 PM
kacz07's Avatar
kacz07
I figured I'd have 270whp without the cams. That would only be around 15-20whp gain with the other mods.
Old Jan 28, 2009 | 01:55 PM
kacz07's Avatar
kacz07
hoping to run into someone with the same setup...
Old Jan 28, 2009 | 02:03 PM
Done Deal DR's Avatar
Done Deal DR
Every car and dyno is different, but if it would make you happy to hear a "magic" 280whp number, fine, that is EXACTLY what those parts will equate to.
Old Jan 28, 2009 | 02:08 PM
kacz07's Avatar
kacz07
haha thanks for trying...I'm completely aware of that, just hoping the relevant eyes come across this thread. I can bear the comment in between.
Old Jan 28, 2009 | 03:01 PM
KS0385's Avatar
KS0385
I wonder what a liquid reflash would give you.
Old Jan 28, 2009 | 03:51 PM
thawk408's Avatar
thawk408
When my revup was NA I put down 282rwhp DJ with JWT popcharger, Crawford Plenum, Crawford headers, test pipes, and borla TD exhaust.
Old Jan 28, 2009 | 04:05 PM
kacz07's Avatar
kacz07
A base case of diarrhea
Old Jan 29, 2009 | 02:59 AM
finalforce's Avatar
finalforce
Wow, that's good stuff. Normally with the Revup's I'm always advised to get the Mrev2 as a combo for the plenum spacer. Looks like you had some good gains with just the spacer.
Old Jan 29, 2009 | 09:19 AM
thawk408's Avatar
thawk408
I also put down 252-255 stock on the same dyno. Whats the MREV2? I tried the 287hp runners on my motor awhile ago and I lost peak power and the car felt slower. There is an old thread about it somewhere.
Old Jan 29, 2009 | 09:38 AM
phinmac's Avatar
phinmac
MREV2 is a lower plenum.. normally for revup motors.. for better explanation check out Motordyne.com.
Old Jan 29, 2009 | 09:39 AM
Nexx's Avatar
Nexx
OP, go and dyno there thawk dyno'd his car!
Old Jan 29, 2009 | 09:43 AM
thawk408's Avatar
thawk408
Same dyno that Doug at Crawford Z did all his testing on. Its a dyno jet, it cant be messed with. My car was a strong one NA tho.
Old Jan 29, 2009 | 10:17 AM
KA24DE's Avatar
KA24DE
The Mrev inhibits the car from breathing as well at top end. I'm not a fan.
Old Jan 29, 2009 | 01:30 PM
finalforce's Avatar
finalforce
Mrev2 is the lower plenum. It is designed with higher collectors so that the cylinders gets more air. BTW, what is 287 runners? Anyways, good numbers. I can't wait to baseline dyno my car before I start installing my engine mods. My garage is collecting parts and I'm just saving for an Osiris.
Old Jan 29, 2009 | 04:44 PM
thawk408's Avatar
thawk408
The MREV2 uses the 287hp motors runners tho as the base, I believe. They are longer then the Revups, helping in torque, but hurting top end.
Old Jan 29, 2009 | 08:38 PM
Let the dyno racing begin!
