Clutch chatter?
Old Feb 11, 2009 | 09:18 PM
neox's Avatar
neox
Default Clutch chatter?
I'm new to the 350, just bought my Z a few months ago. My Z had 72k miles on it when I got it, dealer said he had replaced the clutch not long before the sale. My concern is a chattering noise that seems to be getting more and more frequent. I'm not certain its the clutch, but the noise is only bad when i'm in too high of a gear at too slow of a speed, say going 15mph in 3rd gear. The noise is a loud clatter that will eventually go away once I get up to the right speed in whichever gear, however i've started noticing it occasionally when my car is sitting in my garage, idling, in neutral.
If I drive my car just right, and have my shift points just right... I don't hear the clattering noise at all.
Is my clutch going bad? Is this normal by any chance?
Old Feb 12, 2009 | 05:14 AM
Mymmz's Avatar
Mymmz
do you know if the flywheel is stock?
I had mine replaced and I get a lot of chatter, same thing your experiencing. I thought it might have been the throw out bearing but 400 bucks later it still does the same thing.
Old Feb 12, 2009 | 06:18 AM
Chef-J's Avatar
Chef-J
Booooosstt!!
it's causing from light weight flywheel. Normal if you do have an aftermarket flywheel.
Old Feb 12, 2009 | 06:37 AM
freedonutss's Avatar
freedonutss
Yes its perfectly normal on stock flywheel. If your in a higher gear going a pretty low speed trying to accelerate ex. 3rd gear trying to accelerate from 15mph like you said, you will get some chatter.
Old Feb 12, 2009 | 06:42 AM
genegoesfast's Avatar
genegoesfast
this problem is all based rpm value not speed obviously. The issue is normal stock and even worse with a lightened aftermarket fkywheel...the only solution i have found was cahnging trans fluid for a slight improvement. redline shockproof did really well in decreasing the noise.
Old Feb 12, 2009 | 06:53 AM
Chef-J's Avatar
Chef-J
Booooosstt!!
With stock flywheel, i didn't really hear any chatters. (Maybe i didn't pay aattention)
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
