350z Clutch Problem!!!!!!!!!
Old Mar 22, 2009 | 11:26 AM
Platinumbills's Avatar
Platinumbills
Default 350z Clutch Problem!!!!!!!!!
Hey guys, my clutch on my 03 350z gave out and I bought a stage 3, can I run a stock flywheel with the new stage 3 or will I need to get a new flywheel? Any help would be appreciated thanks.
Old Mar 22, 2009 | 12:42 PM
Haven't the faintest what stage 3 is. Yes you can run the OEM flywheel. But you will most likely want to resurface the flywheel, and that is next to impossible.
Old Mar 22, 2009 | 01:31 PM
Fidanza's Avatar
Fidanza
Who is the manufacture of the stage 3 clutch? davidv is also correct about your oem flywheel... it is definitely recommended to either purchase a new oem flywheel or go with an aftermarket one that best meets your needs.
The oem flywheel is a dual mass flywheel with internal dampening springs and should not be resurfaced. If you need anymore help let me know.
Old Mar 23, 2009 | 07:34 AM
Platinumbills
Its from ebay its an XTD stage 3 clutch. ive been kinda short on money so i had to go with that one, but i heard it was pretty good.
