Knocking sound during acceleration
Old Mar 25, 2009 | 09:00 AM
abeklipse's Avatar
abeklipse
Default Knocking sound during acceleration
The sound occurs during acceleration in 1st through 3rd gear and the sound gets stronger the harder you press on the gas pedal. I have no CEL codes, the engine has about 44k miles, always used 91 octane gas, and my engine oil is up to level.
What do you guys think this could be?
Old Mar 25, 2009 | 09:16 AM
Motormouth's Avatar
Motormouth
you have a small child trapped inside your engine and he wants to get out.
or the dead hooker in your trunk wasn't as dead as you thought. hit her in the head again and retest.
Old Mar 25, 2009 | 09:43 AM
HOMiEZ's Avatar
HOMiEZ
r u stock? if not which mods do u have?
Old Mar 25, 2009 | 09:45 AM
Chromex319's Avatar
Chromex319
ha!
j1234's Avatar
j1234
if it doesnt occur in 4-6 gears then its most likely a transmission problem and not the engine.
Old Mar 25, 2009 | 10:15 AM
abeklipse's Avatar
abeklipse
Not modded much, just a Nismo cat. Another thing I forgot to mention is that when I hit the gas pedal during low rpms between 1k to 3k is where the sound is noticable.
Also thanks for the comedy relief, much appreciated.
Old Mar 25, 2009 | 12:28 PM
jray8's Avatar
jray8
lmao never a dull moment reading motormouth's replies
Old Mar 25, 2009 | 12:33 PM
Motormouth's Avatar
Motormouth
but for seriousness:
- where is the sound coming from?
- if the car is not in gear and you rev it, is it still there?
- does it change with RPM?
- did you reuse the cat brace that is on the stock catalytic converters?
- what year car do you have?
Old Mar 25, 2009 | 04:08 PM
abeklipse's Avatar
abeklipse
1- The sound comes from the front bottom of the car and I can hear it evenly from both sides.
2- There is no knocking when the car is not in gear and I rev.
3- The knocking only seems to happen when I accelerate hard and fast it can be heard from 1k through 3.5k rpms. If I accelerate very slowly and softly through the gears, the knocking is not heard, it's only during brisk acceleration.
4- The cat brace is still there and was not touched when my Nismo exhaust was installed.
5- I have a 2004.5
Old Mar 25, 2009 | 08:10 PM
Motormouth's Avatar
Motormouth
ok, I am going to say it might be either a broken or loose end link. when the weight shifts to the rear under accel it alters the pivot of the end link and could make the noise.
or it's your undertray slappin' against something.
..I mean, how loud is it and is it like a metal on metal knock or plastic sounding?
Old Mar 26, 2009 | 07:12 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Maybe it's actual detonation, that a lot of the 91 octane guys have experienced on otherwise stockish cars. If it's a rocks in a box sound, under load, then it's probably knock.
Sometimes, a simple catch can can help eliminate this minor knock. Oil that is injested through the intake (through your PCV valve) will contribute to knock.
Old Mar 26, 2009 | 09:43 AM
abeklipse's Avatar
abeklipse
It does sound like rocks in a metal box. I will check the intake for signs of oil. Are octane boosters used regularly by 91 octane users in order to prevent detonation?
Old Mar 26, 2009 | 09:49 AM
Sharif@Forged
Forged Performance
Those little bottles of booster don't do anything. I would try the small catch can.
Old Mar 26, 2009 | 05:10 PM
abeklipse's Avatar
abeklipse
Thanks Sharif, I will be picking up a catch can.
Old Apr 7, 2009 | 02:38 PM
Master Shake's Avatar
Master Shake
Have you tried a different brand of gas or different station location? I sometimes get a knocking sound (regular engine knock), similar to what you listed above, with a cheap/no-name brand of gas.
Old Apr 7, 2009 | 06:36 PM
terrasmak's Avatar
Throw a tank of 89 in it and see if it changes. If its actual detination it will get worse.
Old Aug 11, 2009 | 11:24 PM
baopee's Avatar
baopee
I have noticed this same problem recently with my 2004.5. anyone have an update to this old thread? Please let me know. thanks1
Old Aug 12, 2009 | 05:35 AM
str8dum1's Avatar
str8dum1
my beater does this bc of all the oil it burns. I run 93 octane and it all goes away.
Old Aug 14, 2009 | 07:11 PM
dgkn86's Avatar
dgkn86
i have same problem as well i have 35ht anvi and i heard knocking sound when i acc on 1k to 3k rpm;;
and i always use sunoco 93 or shell vpower
Old Aug 16, 2009 | 01:05 AM
baopee's Avatar
baopee
I'm going to get my spark plugs pulled to examine carbon fouling.
In addition, I'm going to check my battery for wear and see if they need to be replaced. Apparently the OP replaced his battery and doesn't hear this noise anymore.... strange
I also noticed a constant, rhythmic noise, sound like a brush scrubbing back and forth near where the electronic throttle control unit is located. Gets faster as I rev the engine.
this is driving me nuts....
