Knocking sound during acceleration
Old Jun 21, 2010 | 09:45 AM
Armed Ferret's Avatar
Armed Ferret
Like I posted in another thread, this sound is likely the normal "gear lash" noise heard on RevUp engines.
Mine does it, as do a couple 35th Anniversary models I've ridden in.
Lighter flywheels will contribute to more noise, but it's not abnormal, and not something to have much concern over. If it gets worse, I'd probably start inspecting parts, but if it's rocks in a coffee can below 2k rpm's when you hit the throttle in any gear, it's just gear lash.
ETA: Post where I found this info:
https://my350z.com/forum/8471455-post15967.html
Old Jun 25, 2010 | 11:34 PM
Orange County's Avatar
Orange County
how can you get rid of the "gear lash"
Old Jun 26, 2010 | 07:33 AM
Armed Ferret
they got rid of it on the 370z by making the flywheel/clutch assembly a little heavier.
Old Jun 29, 2010 | 09:24 PM
WhiteNoiz's Avatar
WhiteNoiz
Yup, mine does it also. It is annoying but harmless from what Ive read. If I remember correctly... otherwise I would have been worried about it I think. I just remember reading a bunch about flywheel noise. Didnt pick up it was actually called gear lash until now.
Old Jun 29, 2010 | 09:32 PM
WhiteNoiz's Avatar
WhiteNoiz
Just a thought. Would leaky a leaky valve cover possibly contribute to this?
Old Jul 2, 2010 | 08:09 AM
driftwood's Avatar
driftwood
a leaky valve cover (gasket) would cause a mess... but that alone doesnt cause drivetrain noise
if you neglect to fix it you will lose oil in a faster pace then normal (if your having oil consumtion issues to begin with)... which in turn can cause some big issues... but i assume you check your oil levels regularly?
Old Jul 2, 2010 | 11:59 AM
WhiteNoiz's Avatar
WhiteNoiz
One theory was knocking from fouled plugs, made me think there could be a possibility of a leaking valve cover, oil leaking down the spark plug threads, and fouling the plug...
I havent checked to see if my car has a leaky valve cover issue, although it sounds very common for that to happen after 50k. I have 60... I'm losing about 3/4 qt every 3500-3800miles. I of course keep it topped off.
Old Mar 11, 2024 | 03:48 PM
Nissanarmy1996's Avatar
Nissanarmy1996
Default Same issue as OP
Originally Posted by Sharif@Forged
Maybe it's actual detonation, that a lot of the 91 octane guys have experienced on otherwise stockish cars. If it's a rocks in a box sound, under load, then it's probably knock.
Sometimes, a simple catch can can help eliminate this minor knock. Oil that is injested through the intake (through your PCV valve) will contribute to knock.
I’m having the same issue as the OP and it’s a very light noise when in gear accelerating hard engine makes no noise at all when in neutral only under load. I have a DE it does leak oil but not burn it. I used 93 gas on last fill up but the quarter tank that was in there is unknown when I bought it.
Obadabot
Jun 18, 2023 11:31 PM
wanderingstuden
Jan 28, 2016 07:03 PM
Justin100
Nov 29, 2015 03:58 PM
samansharif
Sep 25, 2015 12:31 PM
