CEL codes P1288 and P1289
Old Apr 4, 2009 | 07:30 AM
Xendric's Avatar
Xendric
Default CEL codes P1288 and P1289
I got a CEL second time in a week.
First time it was an air temp on the MAP sensor. We got that one reset.
This time we got P1274, P1278, P1279 which I found out after searching that it's got something to do with the AFR sensor.
Also got the P1288 and P1289 codes, that I can't find what they are. Can anyone help with that?
My car has a Vortech kit on it and it's controlled by a Haltech Platinum ECU.
Since I got AFR sensor triggers, it may help to tell you that I've got dual widebands installed, one on each bank of the engine, and I'm getting quite a bit of a difference between the value each one of them displays, when I'm at half throttle. At WOT, they both even out around 11.6 though.
The factory lamda sensors give almost identical readings.
I only have the kit installed a couple of weeks. Never had a CEL trigger before I installed the Vortech.
Any ideas?
Old Apr 4, 2009 | 07:35 AM
cdoxp800's Avatar
cdoxp800
P1288 Switching Solenoid for Air Assisted Injection Valves Bank 2 Control Circuit Signal Low
P1289 Switching Solenoid for Air Assisted Injection Valves Bank 2 Control Circuit Signal High
I have know idea what they mean
Old Apr 4, 2009 | 11:05 AM
Xendric's Avatar
Xendric
Thanks mate!
Anyone knows what they mean?
Old Apr 4, 2009 | 05:38 PM
BrazenZ's Avatar
BrazenZ
I have a haltech and I used to get the same codes, especially when cranking the engine a long time to get it to start. After few days of fine tuning the start-up parameters the codes went away.
As for the O2 sensor readings, You have to calibrate Haltech program so it's sees the same thing that your aftermarkets sensor are sending. Look at O2 sensor calibration for bank1 and bank2 in the lower far left hand menu. Make sure that the After market O2 sensors are displaying the same ratios as the Haltech sees. At 12.0 mine was dead on, but at 14.6 the Haltech was off considerably. Call Hal with Injected performance if you need more help
Old Apr 4, 2009 | 06:25 PM
rcdash's Avatar
rcdash
Those are NOT the codes for our vehicles.
- per my G35 2004.5 FSM:
P1288 is the AFR sensor 1, bank 2 circuit response is slow
"The response (from RICH to LEAN) of the A/F signal computed by ECM from A/F sensor 1 signal takes more than the specified time."
P1289 is the same sensor but indicates:
"The response (from LEAN to RICH) of the A/F signal computed by ECM from A/F sensor 1 signal takes more than the specified time."
Essentially your driver side AFR is not in sync with what the the stock ECU is expecting.
Old Apr 8, 2009 | 01:44 PM
down_shift's Avatar
down_shift
Any solutions for this?
Someone said these might caused by start up issues a few posts up..
OP, are you having problems cranking the car when it's cold or a weird idle?
Old Apr 13, 2009 | 12:24 AM
Xendric's Avatar
Xendric
No solution yet, still getting CELs every few days, and it's the AFR sensors every time. I'm not having start up issues, but, suppose it took 2 secs of cranking to start up when stock, it now takes 4 secs, but never have I had an issue starting up so far.
Idle has been perfect so far too.
Old Oct 2, 2009 | 02:17 PM
SH Luciano's Avatar
SH Luciano
anymore news on this? i just got my haltech installed and have to crank the car a tad longer too...plus i got a handful of codes i'm researching right now, though none are ones you listed.
Old Oct 3, 2009 | 03:51 PM
BrazenZ's Avatar
BrazenZ
Talking
At the time I made this post I thought I problem was fixed but it soon came back. In laymen terms ( I think) the po1288 an po1289 that there exists either a lean or too rich condition in either bank and that the stock cpu is unable to correct in a timely fashion. Since the Haltech controls the fuel mixture not the stock cpu this condition will keep reoccuring especially when you are getting into boost. I doesn't seem to effect the engine performance except that you will always have a CEL and maybe fuel mileage will go down a bit. Finally after a year has gone by and I couldn't get a inspection sticker I took my Z to UPRev in Austin and removed the Haltech and had my factory CPU re-tuned at a total cost of $750. The low rpm response is much better, fuel mileage is up and there have been no CEL's in 2500 miles of driving. I am not saying that the haltech is a bad unit, maybe I could just couldn't find anybody in houston who really knew how to tweak the haltech so I wouldn't have so many CEL's and I could afford to fly in Hal from Haltech to tune the car himself. The answer for me Osiris tuning from UPRev.
Old Apr 24, 2012 | 01:37 PM
UMW350Z's Avatar
UMW350Z
sorry to resurrect, i just had a new ROM file made for my car for Osiris and I get these two codes, running haltech and osiris as well. by 'retune factory ECU' do you mean they just disabled the codes? If so, I have my cipher cable and RT tuning will just click them off for me. I went thousands of miles with no CELs, now after the the new ROM was loaded, I have the codes i used to throw 1288 and 1289 with the UTEC that used to be in there
Old Sep 3, 2012 | 11:30 PM
accordfreak's Avatar
accordfreak
anybody had these codes and resolved it? I only got these codes after i switched a 3 bar map sensor and changed the haltech settings to reflect the 3 bar map.
etkms
Jun 19, 2022 06:30 PM
350Z Project X
Oct 17, 2015 05:16 PM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
Bigsyke
Sep 11, 2015 06:19 PM
