Whats the size of the factory fuel feed hardline?
Anyone know the size of the hardline going from the pump to the engine? Also, whats that other line that goes back towards the tank and disappears somewhere back there...
feed line is 5/16. it looks larger because it has a plastic coating on it.
the other line is the EVAP hose... it connects to the EVAP solenoid and then into the throttle body neck on the plenum
yeah I cant use it with my swap..I guess ill just remove it...take some weight out.
