another clutch problem please help!!!
Old Apr 30, 2009 | 05:13 PM
kevin8086's Avatar
kevin8086
Default another clutch problem please help!!!
ok so i been having the sticking clutch issue so i drained all the fluid and replaced it. feels GREAT, only problem is that when i first start the car i have almost no pressure. if i can manage to get it in gear after a few shifts the i hear a clunk and the pressure is perfect shifts better then ever. problem is that if i turn the car off pressure still GREAT but when i start the car no more pressure again. so only on start up do i have a problem otherwise everything is great.
oh and after start up even if i pump the pedal it will not build pressure i have to drive it in gear and do a few shifts before i hear a clunk or something and then everything is great again
Old Apr 30, 2009 | 05:46 PM
blackblack99's Avatar
blackblack99
Default did ya bleed them, if so bleead them again
Make sure you do them in the right order as well.
Old Apr 30, 2009 | 05:54 PM
kevin8086's Avatar
kevin8086
bleed "THEM"? theres only one nipple on the slave right?
Old Apr 30, 2009 | 09:05 PM
kramykram's Avatar
kramykram
you need to reverse bleed it. get a big syringe and hook a hose to it and then to the bleeder valve. open the valve and push fluid into the slave cylinder. then take off the hose and have someone pump the pedal and hold it to the floor. do this about 5 times. you will be suprised how well it works.
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
