First Mod? Where to start?
Old May 12, 2009 | 02:27 PM
icase81's Avatar
icase81
Default First Mod? Where to start?
I have got a bone stock 06 Z Base that I'm about to begin modding. Obviously its a RevUp motor, and I'm aiming to do bolt ons only. My list of planned mods includes:
Headers
Test Pipes
Y-Pipe
Cat Back
Intake (Maybe, undecided)
Motordyne 1/2" Spacer
MREV 2 lower manifold
Perhaps a crank pulley
Whatever needs to be done software wise (obviously this waits till the end)
My question is, what order should I do these in? I've got a litle bit of money to start collecting parts, and I was thinking headers first as thats the biggest pain in the butt to do. I'm very experienced working on cars and have built more than a few VW race engines for myself and friends. Mechanical expertise isn't the problem, just a lack of knowing my way around the VQ as of yet. Any suggestions are greatly appreciated. Thanks.
Old May 12, 2009 | 02:41 PM
pearlwhite_z's Avatar
pearlwhite_z
i got an exhaust just for personal preferance, not really to make the car faster...it is almost always the first thing i do to my vehicles (did the same to my bike), i got a nismo by the way and i have been happy, as far as best bang for buck you can search and see that it would most likely be the plenum spacer. You could also do things like a drop, better tires or rims/tires altogether and sways etc. I believe the stock intake makes the best hp but i got a popcharger anyways. Check around and decide what you want to do.
Old May 12, 2009 | 03:37 PM
s31t8n8's Avatar
s31t8n8
if youre gonna do the headers first than you might as well do the TP's, y-pipe, and cat back at the same time. Just get a drop-in filter, aftermarket intakes are just for sound. if you're going with the 1/2" spacer your strut bar wont fit, i'm not sure if there are any aftermarket ones that will clear it but do some research see if any do.
btw if you want a crank pulley I might be selling my underdrive pulley set. I bought it off a member on here but never installed it. send me a pm if youre interested
Old May 12, 2009 | 04:07 PM
raf84ny's Avatar
raf84ny
Depending on how big is your budget for the first mode, I would start out with a 5/16 ISO plenum from MD and a MREV2. GL and welcome.
P.S. After that test pipes would be next since it is a big choke point.
Old May 12, 2009 | 04:21 PM
icase81's Avatar
icase81
I should start out by saying that my ultimate goal is to merely run in the 12's. 12.7-12.8 or so. I have yet to run it stock, but I do have a good bit of drag racing experience as I've been doing it for 15 years. I ran a best of 14.001 @ 99.66 in my bone stock mk4 GTI 1.8T, and with about 265-270whp in it I ran 12.50's on very garbage and bald goodyear eagles, so I anticipate approximately a 13.4-13.6 in the Z.
Here's a question, if the 5/16" spacer fits with the stock strut bar and the half inch doesn't, why not just get 3/16" washers and put them under the bolts for the strut bar to lift it up the 3/16" difference between the two?
Old May 12, 2009 | 04:53 PM
s31t8n8's Avatar
s31t8n8
the strut bar will rub against the hood
Old May 12, 2009 | 08:32 PM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
^+1
The 5/16" spacer already uses spacers on the strut bar and is about as tight as you can get while still clearing the hood.
An additional 3/16" would noticeably affect the hood fitment.
Tony
Old May 12, 2009 | 08:35 PM
Sounds like a plan to me. Lets get started.
Old May 26, 2009 | 11:06 AM
Stunnd's Avatar
Stunnd
Originally Posted by Hydrazine
^+1
Tony
If I wanted to go with the 1/2" spacer, is there an available strut bar that works with the stock hood, or is a new hood necessary?
Old May 26, 2009 | 11:21 AM
Hydrazine's Avatar
Hydrazine
A new hood isn't necessary. There are two strut bars (that I know of) that are available.
The Stillen and APS. Either of these will fit with the 1/2" spacer.
Old May 26, 2009 | 12:10 PM
Stunnd's Avatar
Stunnd
Thank you. Now it's decision time.
Old May 26, 2009 | 02:02 PM
davidc81's Avatar
davidc81
hey whats up. i'm from atown and have all the mods you mentioned except my intake is called a "supercharger." i have a 1/2" motordyne spacer and cusco strut bar and it hits the hood. you'll either have to go with one of the strut bars mentioned or bang a pair of indentations into the hood. if you want to meet up some time, let me know and i can show you my car.
Old May 26, 2009 | 04:40 PM
Stunnd's Avatar
Stunnd
Any thoughts on the 1/2" vs 5/16"? I suspect the hp difference is not noticeable, but how about the engine growl? Also, who installed it for you? That's actually more important to me. Thanks.
Old May 26, 2009 | 07:49 PM
davidc81's Avatar
davidc81
it's an easy job so you can probably do it yourself. the extra 3/16" does help make more hp but will give you some problems with the hood fitting. if you're looking for a good shop around allentown, i would suggest add onz. they do all the work on my car.
http://www.add-onz.com/
Dymsi
Sep 29, 2015 11:32 AM
Tochigi_236
Sep 27, 2015 03:40 PM
