Sometimes won't start
Old May 16, 2009 | 08:21 PM
twofallsteve's Avatar
twofallsteve
Default Sometimes won't start
It cranks but won't fire. At first I just thought it was the aftermarket key but it happened once today with the factory key. It has happened about 4 times in the last two weeks and eventually turns over after a few tries.
2004 350Z all stock ignition.
Old May 16, 2009 | 10:52 PM
ironx's Avatar
ironx
i had the same problem see if you can here if the fuel pump turn on when you cycle the key if not check the relay and the fuse for the fuel pump that what the problem was on mine they were lose for some reason hope this helps sounds just like what mine was doing
sherm
Apr 11, 2020 05:21 PM
Dymsi
Sep 29, 2015 11:32 AM
