Big Problem After Tranny Swap!
Old Jun 9, 2009 | 09:35 PM
aguita's Avatar
aguita
Default Big Problem After Tranny Swap!
Hello
**** problem fixed...i removed the sensor and reinstall..but randomly the car does the same around rev limit but not like previously..just a loud shot and then fine..******
but now I got the VDC and SLIP lights on!!
Old Jun 9, 2009 | 10:53 PM
bbs350z's Avatar
bbs350z
are you sure everything was assembled right? throwout bearung, pilot bushing, the splines in all the way? is the tranny oyu bought in good condition? how about all the conections, are they all hooked up? try the simple things first then go from there
Old Jun 10, 2009 | 07:52 AM
davidmcc's Avatar
davidmcc
Like bbs said, start with the little things.
I'd first check all the wiring to make sure it was reconnected correctly and that all the necessary sensors/switches are functioning. I'd also give special attention to the crankshaft positioning sensor. It's very sensitive to impact, metal debris, and magnetic surfaces so if it wasn't handled/stored carefully while the work was being done that could be your problem.
Old Jun 10, 2009 | 08:17 AM
aguita's Avatar
aguita
Everything is connected the car shift smoothly etc..I did noticed that the CPS had some metal debris on it..Ill check that again..
Also On the tranny there are 2 sensor hooked on each side..I dont know if the guy who installed the tranny put the sensors on the correct way..
Are these the speed sensor???
Old Jun 10, 2009 | 07:05 PM
davidmcc's Avatar
davidmcc
Those are just the neutral safety switch and the switch for the reverse lights. ...nothing that would likely cause the type of problem you're having.
Old Jun 11, 2009 | 10:42 AM
aguita's Avatar
aguita
bump
Uriyo_
Sep 8, 2021 08:46 AM
