pulley questions
Old Jun 11, 2009 | 05:25 AM
R11's Avatar
R11
Default pulley questions
I just installed my Unorthodox Underdrive Pulley Kit, and in the morning when i go to start up my car i hear a weird screeching sound, not horrible, but just enought to where i cought it. im pretty sure its comming from the pulleys and i only hear it the verry first time i first start my car. Im thinking the crank pulley might be on too tight... What do you guys think. Is it something to get worried about?
Old Jun 11, 2009 | 07:08 AM
350 Rookie's Avatar
350 Rookie
Its a belt squeel, Usually comes from belt being too tight/loose/low oil in your power steering resorvoir. One way of checking tightenss on a belt is to take the belt and twist it. It should only turn about 1/4 turn or 90 degrees. Anymore, its loose, any less, its tight.
Old Jun 11, 2009 | 02:14 PM
Blew By U's Avatar
Blew By U
its either not the right belt for the kit or the belt is just old and worn out
Old Jun 11, 2009 | 06:03 PM
R11's Avatar
R11
Ill give the belts a tightness check LOL but as far as being worn out they're not, they're brand new, they came with the kit.
Old Jun 11, 2009 | 06:05 PM
Toby-22's Avatar
Toby-22
it's either too tight or too loose, make sure to use a torque wrench when doing this
Old Jun 11, 2009 | 09:46 PM
350ZTheStandard's Avatar
350ZTheStandard
Mine does this mostly in the cold weather sometimes, it is such a pain in the a$$ to get to the belts from under the car, guess I will be joining you adjusting my belts this weekend also. Good luck
issyz
Jul 2, 2017 03:04 PM
Fixxxercask
Nov 9, 2015 11:10 AM
Alexreyes
Sep 30, 2015 11:30 PM
