Clutch Replacement Recommendations '06
Old Jun 19, 2009 | 02:12 PM
CanUZeeMe's Avatar
CanUZeeMe
Default Clutch Replacement Recommendations '06
My clutch is starting to slip with 55k on it. I want to upgrade it but not "break the bank" and desire something comparable to the feel of the OEM. I have a 2006 model.
Any recommendations?
I am located in Washington DC. If anyone knows of a place for the install.
Thanks.
Stephen
Old Jun 19, 2009 | 04:02 PM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
RPS
/thread
Old Jun 19, 2009 | 09:47 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
None of aftermarket clutch/flywheel price can not beat OEM price.
https://my350z.com/forum/drivetrain-420/
If your car is just DD, i would stick with OEM tho, that's just my two cents.
Old Jun 20, 2009 | 01:28 PM
2004Black350z
Exhaust Whore
My RPS clutch and flywheel was A LOT cheaper then OEM
Old Jun 20, 2009 | 01:58 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
How much?
Old Jun 20, 2009 | 04:37 PM
rocks's Avatar
rocks
JWT Clutch kit + flywheel I have had it for over 2 years with no problems.
Old Jun 20, 2009 | 04:52 PM
Welcome. If it looks like the OEM clutch, it will perform similar.
If it looks like above maybe skip it.
Old Jun 20, 2009 | 05:29 PM
dmroberson's Avatar
dmroberson
I went with the ACT Heavy Duty Street Clutch, with ACT Prolite Flywheel...
Old Jun 20, 2009 | 06:27 PM
raf84ny's Avatar
raf84ny
^^^are you experiencing alot of clutch chatter noise? Do you like the performance of the lighter flywheel?
Old Jun 20, 2009 | 08:29 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
I also have same setup as him.
Chatter is loud to me, but not bother me or any tho. Performance? it feels revup faster compare to stock.
Old Jun 21, 2009 | 05:04 PM
dmroberson's Avatar
dmroberson
It does chatter, sometimes quite noticeably, but I love the setup... Yes, it does rev up and down much faster than stock...
Old Jun 21, 2009 | 05:15 PM
Zivman's Avatar
Zivman
Thanks.
Stephen
if you are N/A and don't run nitrous, just get a stocker or a nismo. No reason to "upgrade" if stock feel is what you want
Old Jun 22, 2009 | 01:43 PM
tquill's Avatar
tquill
I'm needing to do the same thing I think. Dealer claims the horrible squeak that comes from releasing the clutch (sound coming from transmission casing) requires labor that would justify just buying a new clutch.
How much does a new OEM or RPS clutch cost with install? Would I need anything else like a flywheel? Car has 95k miles.
Old Jun 22, 2009 | 06:55 PM
Zivman's Avatar
Zivman
RPS will be cheaper than oem. You will need flywheel, clutch, throwout bearing (which is the part that is making the noise) and I would upgrade to a SS clutch line.
Old Jun 23, 2009 | 09:24 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
the OEM is considerably cheaper than RPS. Not to mention the OE clutch can use an OE flywheel, where the RPS requires use of their flywheel
A good, cost effective combo is the Exedy Sport Clutch + ACT flywheel, or the JWT
The flywheel can't be resurfaced, as it's a dual mass unit, but as long as it drive smoothly (no jerking from a dead stop) it could easily be reused.
Old Jun 23, 2009 | 09:55 AM
tquill's Avatar
tquill
What would the cost be of the combos you mentioned plus install? Where should I buy it and where should get them installed?
As for the flywheel, I believe my OEM should be fine... but I'm not really sure.
Old Jun 23, 2009 | 10:00 AM
Z1 Performance
Former Sponsor
parts we can easily provide you....we have them all in stock (pm us)
as far as the install goes, ask in your regional forum for some suggested shops
Old Jun 23, 2009 | 05:06 PM
2004Black350z
Exhaust Whore
Ohh now i see. U dont carry RPS lol i thought this was a actual legitimate post not trying to be a salesman. hmm anyways RPS clutch and flywheel comes with EVERYTHING u need like throw out bearing and was WAY less then what the delaership quoted me and i have a upgraded clutch now and a smoother rev and faster rev and feels A LOT better to me now
Old Jun 23, 2009 | 05:16 PM
2004Black350z
Exhaust Whore
RPS
Clutch
http://www.injectedperformance.com/e...ID=1324&VID=36
Flywheel
http://www.injectedperformance.com/e...ID=1289&VID=36
OEM
Here ya go ill just post factory flywheel
http://www.factorynissanparts.com/pa...layCatalogid=0
Z1
Flywheel
http://www.z1auto.com/prodmore.asp?m...ne&prodid=1973
Clutch (hmmm dont list exedy price it dont matter bc its GARBAGE)
So if u do go Z1 route u will prob be 200$ less with a sh1tty clutch. I have RPS and have had for over 40K miles, Nitrous, Plenty of street/drag racing, Drift event and ohh yeah i tried to teach my gf how to drive a 6 speed.
Counterpunch?
Old Jun 23, 2009 | 06:43 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
RPS
Clutch
Flywheel
OEM
Z1
Flywheel
Counterpunch?
You do drift and drag racing?
