'07 Transmission in an '04... Help!!!
Hello all. I have a '04 model (07/03) with a shot gearbox (No 5th & 6th, hard to find reverse). Is it possible to put in the '07 gearbox since I have one available? I know the slave cylinders were moved into the bell housing, will this be an issue? I couldn't find anything specific on this particular swap from searches... And the 3 $tealerships around here gave me...
1. The only one that'll work is an '04
2. I need vins from both cars, bring them in and we can check em...
3. I don't think the '07 has a gearbox!?!?!
Im thinking, it should fit and only the hydraulic line need to be moved... Also would it be feasable to swap housings?
I posted on another forum but no luck
Thanks.
Thanks.
