Technical Service Bulletin 2004 Z Air/Fuel Sensor
Old Sep 20, 2009 | 05:23 PM
DJADL's Avatar
DJADL
Default Technical Service Bulletin 2004 Z Air/Fuel Sensor
Does anyone know what this is regarding? and possibly what it could be doing cause my Z is throwing a CEL for this exact issue. And HOW DO U FIX ITT!!!!!???
Exhaust & Emissions: ENGINE AND ENGINE COOLING:EXHAUST SYSTEM:EMISSION CONTROL
Service Bulletin Number: 4080
NHTSA Number: 10008715
Model Years Affected: 2004
Date of Bulletin: 08/2004
Bulletin Summary: ESSENTIAL TOOL - J-44626 AIR FUEL SENSOR SOCKET. ALSO INCLUDING 2005 ALL NISSAN VEHICLES.
Old Sep 20, 2009 | 06:45 PM
DavesZ#3's Avatar
DavesZ#3
TSB don't always mean a "problem". Most of them are instructions to dealers on how to handle certain situations that may arise. It's sort of a "DIY". Considering the description there, I'd guess it's instructing dealers in the use of the J-44626 special tool. It's a KENT MOORE J-44626 Oxygen Sensor 22 mm Socket . BTW - that TSB applies to all vehicles Nissan made in 2004.
Why don't you post the code(s) you are getting instead speculating on the solution.
Old Sep 20, 2009 | 08:19 PM
DJADL's Avatar
DJADL
P1283, my bad, I had already made a thread for that issue but I wanted to know if anyone could figure out this one. The reason I speculated was because people told me it had to do with either an air intake leak or a bad air/fuel sensor. Then I found this, and I got excited because I thought something might be an issue with the sensor.....
Sigh, what is very weird is the car runs perfectly fine when the check engine light is off (when it is reset) but the moment it comes back the thing starts acting weird, im wondering if the sensor is crappy, but I dont know how to check it.
liqalu04
Jan 2, 2022 12:58 PM
_bit
Oct 2, 2015 07:49 AM
