Questing about wiring the to the ecu!
Old Sep 28, 2009 | 08:42 AM
G35-31's Avatar
G35-31
Default Questing about wiring the to the ecu!
OK i have a 2003 g35 and i currently have a 2006 rev up engine in it but on a stock de harness so its missing the upper cam sensors the green and blue plugs.. i was woundering if i can just wire thoes sensor's up to the ecu hook up and pin them in and run a rev up ecu. i know nothing about wireing so i mean im not sure it it will function correctly and allow me to rev over the 7k mark.as of now i cant get the timing right idle right so im sure im loosing a significant amount of power..does anyone know if this would work?
Old Sep 29, 2009 | 10:39 AM
bbs350z's Avatar
bbs350z
you can either swap your de heads onto your revup motor, or buy a revup wiring harness and ecu. after that your car will need a key reprograsmming from your local nissan dealership. those are the only ways unless you run a complete standalone like haltech.
Old Sep 30, 2009 | 02:00 PM
G35-31's Avatar
G35-31
damn , i though i can just add the pins to the ecu and it would work!!
350Z_Al
Oct 29, 2020 07:44 PM
nanotech
Oct 2, 2015 05:02 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
