f1 racing clutches
Old Oct 13, 2009 | 02:07 AM
tomei_p's Avatar
tomei_p
Default f1 racing clutches
hi everybody, soooorry for asking regarding a clutch topic but i couldn't find an answer somewhere.
My question is the following:
I own a 2004 z 350bhp n/a and i need to buy a clutch kit with a light weight flywheel. I know that JWT and ACT are one of the best, but i was wondering about the f1 racing clutch..it costs a little less, but i am not sure of its durability (it seems good).
Sometimes what you pay is what you get..but again that depends cause although the car is at 350bhp i never drive it on tracks and so on. I mainly do a road use.
So should i
1) Buy a exedy oem clutch with a fidanza flywheel?
2) Buy a f1 racing kit?
3) Jwt kit?
Of course price does matter!!!
Thanks!!!
Old Oct 13, 2009 | 02:36 AM
Z04's Avatar
Z04
maybe if you actually looked/posted in the right section you would have had better luck
Old Oct 13, 2009 | 03:08 AM
dyss's Avatar
dyss
true.
my $.02... dont sacrafice durability because of the price. get something name brand that you know is dependable... the JWT has had good reviews time and time again. exedy too
Old Oct 13, 2009 | 03:40 AM
*Boose*'s Avatar
*Boose*
If it's not signed by Schumacher then JWT. If it is then I'd say get the F1. BTW wtf is this f1 clutch?
Old Oct 13, 2009 | 04:06 AM
tomei_p's Avatar
tomei_p
i searched but i couldn't find anything regarding the f1 clutches...all topics are reffered to jwt, act, os giken and so on..
if you have seen such a topic show me the link..otherwise an advise would be great...
By the way the shop that offers the kit is good, i have bought in the past a clutch set for an s2000 with no problems..
here is the link
http://cgi.ebay.com/ebaymotors/ws/eB...AQ:MOTORS:1123
Thanks
Old Oct 13, 2009 | 07:54 AM
GT-Z's Avatar
GT-Z
Seems good.... buy it then tell us if it holds up or FAILS!!!!!!
Old Oct 13, 2009 | 11:15 AM
blktrack350's Avatar
blktrack350
what mods do you have that equal 350hp?
Old Oct 14, 2009 | 01:43 AM
tomei_p's Avatar
tomei_p
Air Duct Intake (carbon)
JWT Intake
Motordyne Engineering 5/16 Plenum spacer
Unorthodox pulleys
U-tec ecu
Cp pistons
Supertech Performance valves intake/exhaust
Tomei camshafts 272 degrees
Tomei valve springs
Cosworth High compression Head Gasket
Cosworth High performance rod and main bearings
Nismo oil pump
Nismo thermostat
Nismo radiator cap
Nismo Oil cap
Nissan oem gasket set
Nissan water pump
Nissan gear chains
Nissan Guide chains
Stainless steel braided clutch line Nismo (motul Rbf 600)
Greddy spark plugs 6”
Dc headers
Tomei test pipes
Invidia exhaust true dual
Tein flex
Os Giken twin clutch combo kit
Eibach wheel spacers
Nismo Carpets
Nismo brake pads
Old Feb 20, 2010 | 01:16 PM
vdemon311's Avatar
vdemon311
I just ordered my f1 racing stage 2 clutch and flywheel... ill post back once installed
Old Feb 20, 2010 | 01:31 PM
DB350's Avatar
DB350
JWT Intake
Unorthodox pulleys
U-tec ecu
Cp pistons
Tomei valve springs
Nismo oil pump
Nismo thermostat
Nismo radiator cap
Nismo Oil cap
Nissan water pump
Nissan gear chains
Nissan Guide chains
Dc headers
Tomei test pipes
Tein flex
Nismo Carpets
Nismo brake pads
Bold = 350hp alone
Your numbers are way off. You should be around 600 whp.
Old Feb 20, 2010 | 03:55 PM
krnzzang84's Avatar
krnzzang84
Originally Posted by DB350
Bold = 350hp alone
Hey DB350, does DB mean DoucheBag??
Old Feb 20, 2010 | 04:00 PM
DB350's Avatar
DB350
close
Old Feb 20, 2010 | 08:16 PM
MDK's Avatar
MDK
How is it possible that someone could have all of those very expensive engine modifications and then ask about running a no-name eBay clutch 'to save a few bucks'?
Old Feb 25, 2010 | 10:42 AM
honeybadger's Avatar
honeybadger
doesn't sound like it is worth it for you to get a stronger clutch.
Old Aug 1, 2010 | 09:48 AM
vdemon311's Avatar
vdemon311
As an update to those who are actually interested in the f1 racing clutch. I had the f1 racing stage 2 clutch(the carbonized kevlar) and flywheel installed. 120 miles or so now and it is working pretty good. Slight chatter from the lightweight flywheel at low rpms(just like every other lightweight fly for our cars), but besides that, it engages smoothly with no problem whatsoever
Old Aug 2, 2010 | 07:48 PM
Sylvan Lake V35's Avatar
Sylvan Lake V35
I was wondering the same thing
Old Aug 3, 2010 | 04:43 AM
epidemic007's Avatar
epidemic007
i have the stage one f1....figured id give it a shot, it was cheap enough that if it didnt hold up it wouldnt be a big loss. well all i can say is so far so good. engagement is great, feel is not much different from stock but def grabs harder. imo not a bad buy.
Old Aug 14, 2010 | 03:39 PM
ZSpeedPerformance's Avatar
ZSpeedPerformance
Vendor - Former Vendor
F1=Made in China, Much like Competition clutches.
Not really what I want spinning at 7,000+ RPM a foot from my feet, but that's just me
Old Aug 14, 2010 | 08:10 PM
Tackett's Avatar
Tackett
Let's see the Dyno sheet for this HP claim on those mods....
Old Aug 14, 2010 | 08:18 PM
xzotklr's Avatar
xzotklr
You're so silly!!
