resonance frequency
Old Dec 6, 2009 | 02:44 PM
Mafra88's Avatar
Mafra88
Default resonance frequency
I have a 2003 350Z base 6MT with 50k miles. I recently had the 3rd gear assembly rebuilt under a third party warranty due to a failed synchronizer. Since the transmission was being rebuilt, an oem clutch and flywheel assembly was also installed. The car drives fine at local speeds; however on the highway in the ranges of 55-70 MPH a deep resonance frequency can be heard. While I have not pin pointed the sound, it seems to be emanating from the engine area. Any help would be greatly appreciated.
-The noise persists while the clutch is pushed in.
- Flywheel chatter is more evident even though it is an oem setup.
Old Dec 6, 2009 | 03:34 PM
TreeFiddyZee's Avatar
TreeFiddyZee
Do WHAAAAT!?
Might be your driveshaft binding. Mine did it quite a bit. Mine was more of a rumble that you could feel. Another option might be your throw-out bearing.
Old Dec 6, 2009 | 06:18 PM
diablox1's Avatar
diablox1
I had the exact issues ur describing but not on my Z, (on my truck). it ended up being my ujoints. i replaced them over a weekend, and eliminated the vibrating.
Old Dec 6, 2009 | 06:56 PM
Mafra88's Avatar
Mafra88
There isn't any noticeable vibration rather it is an audible low pitch frequency. The steering wheel and chassis have no noticeable vibrations.
sales@czp
Sep 23, 2019 03:30 PM
nanotech
Oct 2, 2015 05:02 AM
Red G Coupe
Videos
Sep 8, 2015 08:36 AM
