CEL blinks when reving.
Old Jan 23, 2010 | 11:05 AM
sinecter's Avatar
sinecter
Default CEL blinks when reving.
I changed out my test pipes (because they where cracked and kept popping up CEL 1273.) with some berks HFCs and now when I rev up the CEL blinks like its giving off a knock?¿ But it doesnt stay and when I check for codes, everything is clear. Any Ideas? I also changed out my knock sensor+harness before that since it had a knock sensor code up. That went away and never came back.
Any ideas?
Old Jan 23, 2010 | 02:27 PM
TheFarmer's Avatar
TheFarmer
How's your engine running? Blinking CEL is for severe misfiring. Since you changed out your knock sensor wiring, I would double check all the stuff you took off to make sure they're on back correctly
Old Jan 25, 2010 | 08:46 AM
QuadCam's Avatar
QuadCam
as farmer said, the flashing CEL is from an individual cylinder misfire. Random misfires are no big deal.
Get a code scanner and check the code that came up. It will probably have a P030X. *the X will be an actual number from 1-6. what ever number comes up the cylnder with the misfire. For example, a P0305 is for a cylinder #5 misfire.
A P0300 code is for random cylinder misfires.
Old Jan 26, 2010 | 07:12 PM
sinecter's Avatar
sinecter
There where no codes being stored after the misfires happened. I got home, checked around the engine bay, nothing was out of place. I decided to disconnect the battery for like 2 hours, and it seems to have fixed the problem. 150 miles with no check engine light showing its ugly light. So im a happy guy. Thanks for the response guys.
Bigsyke
Sep 11, 2015 06:19 PM
Darkspy
Sep 7, 2015 09:09 PM
raceboy
Sep 19, 2005 09:36 AM
Z PHAT Z
Jul 22, 2003 01:36 PM
