Clutch help needed
Old Feb 11, 2010 | 06:44 PM
silents1ick's Avatar
silents1ick
Default Clutch help needed
hey guys i have 06 6spd base z with about 35k miles on it..
i dont know whats going on but i think my clutch is gone... while driving what happens is when i give gas i hear the engine rev but it doesnt go newhere and then suddently it moves. this happens between 2k and 4k rpm on almost every gear after 3rd.
i know most of the people where will say do "SEARCH" but i did and couldnt really get the right answer..
so i have 100k bumper to bumper warranty from nissan.
my questions are
1.) would this be covered under warranty or will be consider as wear and tear?
2.) if i get aftermarket clutch would it void the warranty?
3.) If NOT, then what are the best options i should look at... z is my daily driver and i take it 2 autocross once in a while and do drive bit aggressive time to time.
Thanx
Old Feb 11, 2010 | 06:51 PM
sdZ33's Avatar
sdZ33
Some parts of the clutch are covered under warranty but if it's the wear and tear parts, I doubt it... Look at your warranty booklet and it has the parts list that is covered... GL
Old Feb 11, 2010 | 08:16 PM
There are some excellent How to verify a slipping clutch? threads. I am certain because I wrote several.
THere are a variety of Aftermarket clutches to fit your needs. Performance and feel similar to OEM clutch at a considerable savings.
Old Feb 13, 2010 | 02:19 AM
silents1ick
so i took it nissan its definately the clutch... the estimate they gave me was 2289. and some change on it. jus to do clutch and flywheel.
i decided to get aftermarket clutch and flywheel.
i m getting South Bend DXD OFE Stage 3 and F1 18lb flywheel....
Old Feb 16, 2010 | 08:09 AM
musubi's Avatar
musubi
That price sounds about right. They get you on the flywheel.
I'm thinking it'll void the powertrain warranty though.
Old Feb 18, 2010 | 06:01 PM
leakyZ's Avatar
leakyZ
$2289!! holy S**T!! thats money!! I dont really use the dealer, hence why Im so amazed at the price.
GL with your new setup
Old Feb 18, 2010 | 06:50 PM
TheFarmer's Avatar
TheFarmer
The factory flywheel is like $900-$1100 depending on your dealer, that's where the bulk of the cost is.
Old Feb 19, 2010 | 04:46 AM
leakyZ's Avatar
leakyZ
Yea so I guess with the labor.....but wow
Z King
Vendor Wanted
13
Oct 22, 2015 11:39 AM
