High Temp Wrap
Old Mar 18, 2010 | 09:20 PM
JE'S350z's Avatar
JE'S350z
Default High Temp Wrap
Where can i find some high temp material to wrap my clutch line in. I am going to be replacing my clutch fluid with motul and wanted to wrap the line for extra heat protection but all i can find is exhaust wrap. I want something that looks more like the material on the stock clutch line if i can find it. Thanks.
Old Mar 18, 2010 | 09:58 PM
terrasmak's Avatar
I took the stock covering off my clutch line and installed if on my braided line when i did the swap, i don't know if you swapped to braided or not, the stock covering seems to help a lot. You can also order shielding from Jegs and summit http://www.jegs.com/p/Thermo-Tec/The...46452/10002/-1
Old Mar 19, 2010 | 01:31 AM
JE'S350z's Avatar
JE'S350z
thats exactly what i was looking for. thanks
