Is the Quaife LSD a 1.5?
Old Apr 15, 2010 | 02:22 PM
agunter33's Avatar
agunter33
Default Is the Quaife LSD a 1.5?
Like the title said, is the Quaife LSD a 1.5? I have spun a few times because I let my foot off the gas through a turn and some one said a 1.5 will help. Im shure anything over my open diff will help. Thanks
Old Apr 15, 2010 | 03:36 PM
Z1NONLY's Avatar
Z1NONLY
I don't think the Quaife is directly comparable to standard clutch-type LSD's. It transfers torque to the wheel with the most resistance, (grip) and it does so in a progressive, transparent fashion.
I went from an open diff to the Quaife, and love it.
Yes, it is far better than an open diff.
*edit* forgot to address the lift-throttle oversteer....
It's normal for the rear to get light (in a turn) when you lift off of the throttle quickly or tap the brakes. However I didn't notice anything that felt out of the ordinary before or after the Quaife.
The primary problem I wanted the Quaife to address was traction out of corners. It works great for that, and since it's operation is so smooth, I have never felt it upset the car.
Old Apr 15, 2010 | 05:21 PM
INTIMAZY's Avatar
INTIMAZY
Quaife makes a fantastic unit. I don't know how much it can help when letting off the gas midturn (I was instructed never to do so unless I want to rotate). The track experts may be able to chime in on driving technique.
The Quaife lets you get on the gas farrr sooner through a corner. It just powers right out with very little drama.
Old Apr 15, 2010 | 06:02 PM
blue350zed's Avatar
blue350zed
http://lmgtfy.com/?q=350Z+Quaife+LSD
Old Apr 15, 2010 | 06:34 PM
agunter33's Avatar
agunter33
Glenn350zHR
Drivetrain
Nov 30, 2015 08:21 AM
bcoffee20
Nov 19, 2015 06:39 PM
Paul.
Oct 16, 2015 07:34 PM
RiujinZero
Sep 25, 2015 01:19 PM
3vilbunny
Sep 13, 2015 12:31 PM
