need a quick answer in the middle of a project??
Old May 14, 2010 | 04:29 PM
crsracing19's Avatar
crsracing19
Default need a quick answer in the middle of a project??
simple question where is the drain point for the power steering i looked over the fsm and could find a pic of the drain point can anyone tell me really quiclk
Old May 14, 2010 | 05:18 PM
terrasmak's Avatar
None, pull the line at the cooler to drain, start car for a second while having something ready to collect fluid if you need a complete draining
Old May 14, 2010 | 05:23 PM
westpak's Avatar
westpak
SFZCC
there isn't a "drain plug" you have to disconnect lines and drain, but why? what are you trying to do?
Old May 14, 2010 | 05:46 PM
crsracing19
my fluid is way way dark im just going through and changing out all my fluids today
Old May 14, 2010 | 05:56 PM
terrasmak's Avatar
JUst buy a power steering cooler and wait to install it, then swap the fluid. For normal changes i just use a suction gun. Suck it out once, refill, run car for a minute turn wheel a couple times, suck it out again, refill, done.
You checking out Cal speedway in the couple weeks?
350Z_Al
Oct 29, 2020 07:44 PM
samansharif
Sep 25, 2015 12:31 PM
