Manual trans fluid
Old May 28, 2010 | 05:10 PM
GreenGoblin's Avatar
GreenGoblin
Default Manual trans fluid
I just got around to putting fluids in my car. So I topped off the transmission with M1 75w-90... It didn't even cross my mind until after I was cleaning up, but I checked the back of the label and it is GL5. I went back to Pepboys and they do not stock GL4.
Any thoughts, I see that Royal Purple is both GL4 and GL5 compatible.
I have been reading that some people say the GL5 will eat away the yellow metals in the tranny, then other people say that new formulas will not eat away the yellow metals.
Any one have any links or additional information.
Thank you.
Old May 28, 2010 | 05:27 PM
CJohnson_350z's Avatar
CJohnson_350z
+1 help him out
Old May 28, 2010 | 06:21 PM
Bigalow's Avatar
Bigalow
Use OEM. I really wanted to use name brand fluids but I changed my mind after reading this:
https://my350z.com/forum/vq35hr/4087...rinds-5th.html
My new Z came with motul trans (or some other) fluid but it sux and my shifting is crappy. I changed my old Z's MTF with OEM and I was completely happy with it. I'll do the same for my new Z.
Old May 28, 2010 | 06:28 PM
terrasmak's Avatar
Amsoil and call it good
Old Jun 4, 2010 | 01:54 PM
pony_killer's Avatar
pony_killer
Arada ninda apa
I use motul in my trans and rear diff and couldn't be more pleased..car shifts and drives perfectly and I think it actually helped with the "notchyness"
Old Jun 4, 2010 | 01:55 PM
pony_killer
Arada ninda apa
but back on topic, if the owners man says only use GL-4 then that's what I would use
Old Jun 4, 2010 | 02:01 PM
Bigalow's Avatar
Bigalow
I have motul in my 'new' Z and it sux hardcore. I'm going with OEM when I recoup more funds.
Old Jun 4, 2010 | 02:50 PM
dirtbikr's Avatar
dirtbikr
try a redline blend, i love it in all of my manual transmissions.
Old Jun 4, 2010 | 03:00 PM
TheFarmer's Avatar
TheFarmer
Amsoil GL-4 or stock Nissan
Old Jun 6, 2010 | 10:42 AM
krnzzang84's Avatar
krnzzang84
amsoil or redline!!!
shift like butter, I guarantee it
Old Jun 6, 2010 | 11:45 AM
raycs7's Avatar
raycs7
I had to visit several pepboys to get enough GL4.
GL5 is not recommended...
Old Jun 6, 2010 | 12:36 PM
NyCSnEaK's Avatar
NyCSnEaK
Amsoil is great in the Spring, Summer, and Autumn. But in the Winter, its not going to be as smooth till you've been driving for a bit and the fluid warms up. The 1-2 shift will be very notchy or grind if you try to force it, when first starting out. Solution = double clutch it into 2nd or rev a lil higher then you normally would and slip it into 3rd. OEM fluid is the most trouble free for our trans, but I do not drive my car after October so no worry for me. I like the longer change interval and better basestock of Amsoil.
Old Jun 6, 2010 | 04:30 PM
krnzzang84's Avatar
krnzzang84
I had redline at winter and it was GREEEEATE, lesser gride than my OEM
Old Jun 7, 2010 | 08:08 AM
bryan@Z1's Avatar
bryan@Z1
Vendor - Former Vendor
We use Redline MT-90 or Amsoil MTG
Old Jun 7, 2010 | 10:45 AM
jonnylaw's Avatar
jonnylaw
The only factory fluids I use are coolant and manual trans.
Old Jun 19, 2010 | 04:51 PM
Bigalow's Avatar
Bigalow
Sorry, I posted that I was using motul trans fluid. I'm not.
It's actually redline in there and it sux. I mean, it seems to work ok when the tranny gets hot. I imagine that would be great for long track runs but OEM is MUCH better for just driving the Z.
I say go OEM if you drive your car a lot. Moreover, the Nissan MTF should be ok for track use as long as you change it frequently (before and/or after track days depending on what you do exactly).
Old Jun 19, 2010 | 04:54 PM
GreenGoblin
I ended up buying oem
Old Oct 4, 2010 | 03:43 PM
Bigalow's Avatar
Bigalow
As an update I'm using Motul gearoil. It's still not as good as when I had OEM but its better than Redline. Nissan, unfortunately, does not make anymore tranny fluid for our car.
Old Oct 6, 2010 | 12:46 PM
pony_killer
Arada ninda apa
Old Oct 6, 2010 | 01:05 PM
Bigalow's Avatar
Bigalow
[/B]
They don't make MTF anymore.
