Boosted LS2 350z
Old Jun 20, 2010 | 10:03 PM
  #41
ttuberz's Avatar
ttuberz
Marks ls2 p88 turbo build is one of the best builds i have ever seen. Hes quite the genius and cool guy. No one knows the real side to the fender story. I'll be sure to post pictures of an upcoming shoot so you can get out your haterade and enjoy
beauties and the beast...
Old Jun 21, 2010 | 01:06 AM
  #42
Havok_RLS2's Avatar
Havok_RLS2
My answer to the VQ problem.
* OLD BUILD *
My Turbonetics Z before the Boooooom!
* CURRENT BUILD *
ENGINE -
GM LS2 6.0 liter V8
Sikky Solid Motor Mounts and Swap kit
Sikky Long Tube Headers
Sikky Custom Aluminum Drive Shaft
Sikky Custom Aluminum LS2 oil pan - 7 quarts
Sikky Custom oil filter relocation kit
JE Performance Custom 3" Dual exhaust
JE Performance Custom 3" Stainless Steel Cold Air Intake
SLP Harmonic Balancer (25% Underdrive)
F.A.S.T Billet Fuel Rails
AAM stage 2 Fuel Return System
Walbro fuel pump 255LPM
Aeromotive Fuel Pressure Regulator
DRIVETRAIN -
TREMEC T56 6 speed transmission
Sikky 350z Clutch master cylinder adapter plate
Wilwood Clutch master cylinder
Wilwood Clutch master cylinder Remote bleeder system (*Prototype)
Fidanza Kevlar Twin Disc Clutch w/Aluminum Flywheel
Billet Products GTO short shifter (customized by JE Performance)
TUNING -
Tuned 350z ECU Tuned by James Evans (JE Performance)
HP Tuner Pro GM LS2 PCM Custom Tuned by James Evans (JE Performance)
WHEELS -
Volk Racing Gunmetal GT-7 (19x9.5/19x10.5)
BRAKES -
Wilwood BBK
14” 6 Piston SL Front
13” 4 Piston SL Rear
Stainless steel brake lines
SUSPENSION -
Buddy Club F&R True Coilovers
Battle Version 350z Camber Arms
Battle Version Rear Toe Links
FUTURE MODS -
Lingenfelter CNC Ported L92/LS3 Cylinder Heads
Livernois Motorsports Stage II cam 232/236@.050,.600 /112 LSA
Yella Terras Shaft Mounted Roller Rocker Arms – 1.7
GMPP Hollow Intake and Sodium filled Exhaust Valves
Patriot Gold LS Dual Valve Spring & Titanium Retainers - .660
Comp Cams 4130 Chromemoly Pushrods - 7.400
F.A.S.T 102mm LSXR Intake Manifold
500+whp N/A coming soon
Old Jun 21, 2010 | 03:03 AM
  #43
MDHRZ's Avatar
MDHRZ
^Very nice. Do they do any 2JZGTE swaps at JE?
Old Jun 21, 2010 | 04:37 AM
  #44
The Fallen's Avatar
The Fallen
Got that off the G site. Turbo looks small.
Old Jun 21, 2010 | 11:06 PM
  #45
Havok_RLS2's Avatar
Havok_RLS2
Yes they do and RB swaps as well if you have the cash flow.
Old Jun 21, 2010 | 11:16 PM
  #46
Havok_RLS2's Avatar
Havok_RLS2
I'm sure it gets the job done for him though.
Hey you know if he is daily driving that thing or is it just set up for race?
It appears that he's running a smaller radiator with a pusher fan on the front.
Old Jun 22, 2010 | 07:02 PM
  #47
maynard073's Avatar
maynard073
I frankly don't care which car is faster when it comes down to it. I'd have more respect for someone cramming an lsx based powerplant into something, not to mention boosting it. That car strikes fear into the heart of most domestics.
Old Jun 22, 2010 | 07:12 PM
  #48
phreaktor's Avatar
phreaktor
Design Engineer
I've never seen a definitive answer to how much that actually costs to do after purchasing the motor and trans...
Anyone care to share or PM me?
Old Jun 22, 2010 | 07:24 PM
  #49
KingBaby's Avatar
KingBaby
Hardest Setting
ah lot of money...ahahahah reliable but cost just as much....
I'm still a guy all about the twins...done right for right under 20k including used HR motor...
Old Jun 22, 2010 | 07:27 PM
  #50
Alberto's Avatar
Alberto
Cranky FI Owner
How much power?
Different strokes for diff folks, I thought this was ghey till I saw an LS in a Z here locally, that $Hit gave me a chub. EDIT-didnt read the thread, the car I speak of is Havoks above!
I wont lie Ive contemplated doing this and taking the VQ to the range to shoot slugs thru it.
11.3 @ 129 with a 75 shot not bad at all. Id personally go for ultimate "beat it all day" NA reliability and run 10's than deal with traction issues all day and spin to 11's with higher trap.
Old Jun 22, 2010 | 08:26 PM
  #51
The Fallen's Avatar
The Fallen
I know he made 733/677 on 12psi and above that spins on the dyno. Its on youtube. And I know for a fact he daily drives it because I see it everywhere all the time...even in the rain like today.
http://www.youtube.com/watch?v=XKS4mZ_ioOA
http://www.youtube.com/watch?v=Xjitz70DtY4
Old Jun 23, 2010 | 03:37 AM
  #52
Havok_RLS2's Avatar
Havok_RLS2
It really depends on if you do all the labor yourself or send it to one of two know shop that specialize in this swap. Either way if money is a factor then my advice would be not to attempt it. Getting your hand on a LS motor and trans was the easiest part.
If you need me to up a number to it then I'd say you should expect to spend more the 20+k. If your going the work yourself you can expect to shell out only a little less than that. NO SHOP WILL QUOTE YOU AN ESTAMATED COST UNTIL THE WORK IS DONE and if they do THEY LIE!
I personally handed my Z over to JE Performance with a blow motor and told then to spare no expense. For what it cost I could have just bought another Z. For the money I've invested (BLOWN) on my Z since I purchased it new in 2005 I could have bought a new Viper or 911 with money left over.
If you can see yourself getting rid of the Z in the nest few years then you shouldn't even think about doing this swap.
This swap isn't just about swapping in a LS and trans and calling it done, it's rebuilding the car from the ground up to handle it. Brakes, suspension, fuel system, electrical system, and custom fabbed everything else. No more off the self replacement parts in some cases. I'm sure if snyper was still here he would back me up on this. Quamen is the second only person I know of on this forum who doing all the work himself but he's the exception because he's used to building race cars. Custom fabbing and welding is nothing much to him but I still bet he'd say the same.
Truth: I never would have considered this swap if I didn't love the Z so much (this is my second one I also used to own a 93 300zxTT) and my VQ haddn't blown up.
Old Jun 23, 2010 | 03:40 AM
  #53
Havok_RLS2's Avatar
Havok_RLS2
Originally Posted by Alberto
How much power?
Old Jun 23, 2010 | 03:45 AM
  #54
Havok_RLS2's Avatar
Havok_RLS2
Tell him I think he's insane (in a good way). LOL
Is he on a stock bottom end? What other engine mods besides the cam and turbo?
Old Jun 23, 2010 | 06:03 AM
  #55
Quamen's Avatar
Quamen
You lie....
Old Jun 23, 2010 | 06:30 AM
  #56
Alberto's Avatar
Alberto
Cranky FI Owner
Originally Posted by Havok_RLS2
When you do the heads, I want a ride in your car.
Old Jun 23, 2010 | 07:04 AM
  #57
Havok_RLS2's Avatar
Havok_RLS2
If it's you no problem.
Old Jun 25, 2010 | 01:34 PM
  #58
Citrus's Avatar
Citrus
LoL at this douchebag^^^. I know the owner and he was actually banned for bad mouthing intense because he said their turbo kit sucked. And then someone bought a fender roller off of him and something happend and he actually tried giving the money back but the guy insisted on getting the roller and then had a moderator give him an ultimatum and the kid told the mod to **** off then got banned. There is two sides to every story and honestly I don't think the kid really tried to screw someone out of a fender roller. From what I see in his build I couldn't see him needing to screw someone out of a 100$.
The fender roller buyer was me:
I send him money for a fender roller in March, I get nothing. Eventually, he tells me he's lost a part to it and that he's trying to get the part replaced. Another two weeks later, he offers a refund, but says he can still get me the fender roller if I just wait. So I choose to wait. Paypal's 30 day window comes and goes. I ask the seller for a refund, he says his account is locked. This goes back and forth for 5 MONTHS, at which point, the mods catch wind of what's going on when I post in his build thread that he still owes me money. I still give him a month to either refund my money or send me the parts he has (and I'll f*ckin fix the roller myself) and he does neither and gets banned in July. I don't think he set out to screw me out of $185, but in the end, that's what happened.
Feel free to send me $185 on his behalf if you think he's such a good guy. I'm sure he'll repay you... LOL
Attached Thumbnails Boosted LS2 350z-snyper1.jpg   Boosted LS2 350z-snyper2.jpg   Boosted LS2 350z-snyper3.jpg   Boosted LS2 350z-snyper4.jpg
Old Jun 25, 2010 | 03:22 PM
  #59
The Fallen's Avatar
The Fallen
I spoke with him today and he has had no problem paying you back as you stated.
He said you left out the part where he initially asked to give you a refund for the lost part but you said no you wanted the roller. Im not taking sides nor getting involved in an argument between the two of you. Hes banned on here and can't talk to you to fix the situation so try messaging him on g35driver.Like I said though, I cant see him needing to screw you out of a 185$ part. In my opinion you are both wrong. You two should work this out without making him look bad saying he scammed you and he should of found a way to pay you back quicker.
Old Jun 25, 2010 | 04:44 PM
  #60
tylerxfire's Avatar
tylerxfire
all i was thinking the whole time was how stupid it is to buy a fender roller your gonna use most likely one time...rent it for less than 50 bucks and send it back...
like stated this guy with the ls2 is on g35driver so pm him there...
