4.08 swap directly from frontier?
Old Jun 10, 2010 | 02:36 AM
iconn350Z's Avatar
iconn350Z
Default 4.08 swap directly from frontier?
I know that the 4.08 final drive is stock for the frontier. I would imagine the final drives out of these vehicles would be in pretty good shape and relatively un-abused.
Is it possible to go to a junk yard and pick up a final drive from a frontier?
Other than bearings and bushings or the install kits that come along with the other final drives out there, what else would be needed to get this to work?
Also, I tried reading through the seemingly endless pages of final drive threads and some started to get off track but no one ever said if this is a true swap.
Old Jun 10, 2010 | 03:08 AM
0jiggy0's Avatar
0jiggy0
Yes. It's where the FD comes from but Good luck finding a 4 cyl king cab that was crashed.
Old Jun 10, 2010 | 08:45 AM
tiguy99's Avatar
tiguy99
Do they come with an LSD too?
Old Jun 10, 2010 | 03:08 PM
0jiggy0's Avatar
0jiggy0
No idea, do it like I did and do a real diff at the same time.
Old Jun 10, 2010 | 04:59 PM
rdrfronty's Avatar
rdrfronty
No, the 4cyl frontiers never came with LSD.
Old Jun 10, 2010 | 08:43 PM
winchman's Avatar
winchman
I thought outer space was the only frontier left.
Old Jun 11, 2010 | 03:21 AM
0jiggy0's Avatar
0jiggy0
Do that **** again and I'll find a way to take control of a mod's acct to ban you.
Old Jun 11, 2010 | 12:27 PM
Chebosto's Avatar
Chebosto
i lul'd.
Old Jun 12, 2011 | 02:30 PM
Chrisvlad's Avatar
Chrisvlad
Quick question guys. I've read a few more threads about this and from what I've read is that everyone who has done this gear ratio swap used the 4.08 gear ratios from a 2006 Frontier for a 370z rear differential. I believe the gear rations I have came out of a 2005 Frontier. Can anyone verify if the 2005 ring and pinion will work with the 370z swap ? I have a 2004 Base Manual 350z and the rear diff from the 370z is also a manual so I know it will fit. I took it to a rear differential specialist and he said he couldnt fit the 4.08 ring and pinion into the 370z rear diff. Any info would be greatly appreciated.
Old Jun 12, 2011 | 05:10 PM
kingkai's Avatar
kingkai
It is the final frontier after all
Old Jun 12, 2011 | 05:16 PM
DB350's Avatar
DB350
Old Jun 12, 2011 | 05:19 PM
0jiggy0's Avatar
0jiggy0
Sometimes I wonder what I'm on when I post stuff like that.
Old Jun 14, 2011 | 03:39 AM
Lawn Dart's Avatar
Lawn Dart
It's definitely not something the average person can do. You need hundreds of dollars in tools and tons of experience.
sales@czp
Sep 23, 2019 03:30 PM
SpartanZ32
Oct 22, 2015 09:36 AM
Tochigi_236
Sep 27, 2015 03:40 PM
SharX59
Sep 27, 2015 09:23 AM
