Clutch issue
Old Aug 12, 2010 | 01:58 PM
TreFITTY's Avatar
TreFITTY
Thumbs up Clutch issue
Hey guys, was wondering if I could get some help for this...today my clutch seemed to be getting stuck at the top before a full release. What does this mean?
Old Aug 12, 2010 | 03:23 PM
TreFITTY's Avatar
TreFITTY
I've also read a couple other forums about this, neone else have this issue?
Old Aug 14, 2010 | 06:15 PM
shiftdrift06's Avatar
shiftdrift06
Its actually a pretty common problem. You should search.
Most common solution is to upgrade to SS clutch line and better brake/clutch fluid.
Also check the slave and master cylinder for leaks.
Old Aug 14, 2010 | 06:53 PM
zero_shift's Avatar
zero_shift
my car had the same problem, so i took it to the stealership and they wanted to replace the master cilinder and flywheel for $3,200 needless to say i went with the ss line and replaced the master cylinder myself.
Old Aug 14, 2010 | 06:55 PM
c0ld29's Avatar
c0ld29
okay I'll list the steps that seem to be proven in order from cheapest/easiest to most expensive/time consuming once again.... but only because I like your name
1) Simply change clutch fluid
if that does not work
2) Change clutch lines to SS lines
3) change master and slave cylinder (as most of the time it is the slave, but you might as well change the master while you are at it)
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
