Clutch/Slave Cylinder/ Warranty question...
Old Aug 21, 2010 | 09:01 AM
huanandonly's Avatar
huanandonly
Default Clutch/Slave Cylinder/ Warranty question...
I recently just hit 37K plus miles on my 2007 Z and the clutch is having that "stuck" issue that is the source of the 2007 slave cylinder recall. Eventhough my car doesn't fall within those numbers on the recall....it shows signs of this problem once in awhile. I called the dealership about it and...they told me that my warranty is already up and that it's part of "wear & tear", so i wouldn't be covered anymore. My question is... if it's the slave cylinder, then wouldn't it still be covered under the DRIVETRAIN warranty?...which is good for 50k miles? Any info would be great...thanks!
Old Aug 21, 2010 | 09:08 AM
DavesZ#3's Avatar
DavesZ#3
Did you look at the warranty manual that came with you car? It explains what's covered.
■ POWERTRAIN COVERAGE
• The Powertrain coverage period is 60 months or 60,000
miles, whichever comes first.
• This warranty covers any repairs needed to correct
defects in materials or workmanship.
• Powertrain coverage applies to components listed below,
supplied by Nissan except for those items listed
under the caption “WHAT IS NOT COVERED”.
ENGINE
Cylinder heads and block and all internal parts, rocker
covers and oil pan, valve train and front cover, timing chain
and tensioner, oil pump, water pump and fuel pump, fuel
injectors, intake and exhaust manifolds and supercharger,
flywheel, seals, and gaskets.
TRANSMISSION AND TRANSAXLE
Case and all internal parts, torque converter and converter
housing, automatic transmission control module, transfer
case and all internal parts, seals and gaskets, clutch cover
and housing, and electronic transmission controls.
DRIVETRAIN
Drive shafts, final drive housing and all internal parts,
propeller shafts, universal joints, bearings, seals and gaskets.
It doesn't really say anything about the clutch or slave, so I doubt it's going to be covered.
Old Aug 21, 2010 | 09:22 AM
huanandonly
Oh man... that sucks I was praying that it would be.
Old Aug 21, 2010 | 09:41 AM
huanandonly
But wait, DavesZ#3... i just read this from Repair Pal Auto Repair Encyclopedia....(http://repairpal.com/clutch-slave-cylinder-replacement) it says,... "The clutch slave cylinder is directly attached to the manual transmission CASING." ---- therefore, according to the Nissan warranty info on what's covered:
"CASE and all internal parts, torque converter..."
...wouldn't the slave cylinder be actually covered??
Old Aug 21, 2010 | 09:49 AM
huanandonly
....and i know that on the 2007 models, the slave cylinder in INTERNAL and the tranny has to be dropped to get at it. Any thoughts?
Old Aug 21, 2010 | 10:20 AM
DavesZ#3's Avatar
DavesZ#3
By the same argument, the clutch is inside the case as we all know, it's (virtually) never covered.
If we're going to split hairs - the clutch slave is attached to the outside, it's not internal to the case. You can change it without removing the transmisson.
I'm playing devils-advocate here. While I don't agree with the wear-n-tear argument of the dealer, it's technically not an internal part of the transmission, it's a support mechanism.
You can always contact Nissan North America and argue your case.
Old Aug 21, 2010 | 10:28 AM
winchman's Avatar
winchman
"If we're going to split hairs - the clutch slave is attached to the outside, it's not internal to the case. You can change it without removing the transmisson."
It's not really INSIDE the case, but you DO have to remove the transmission to get to it.
Maybe we should ask Bill Clinton. He was good at spitting hairs.
huanandonly
hmmm... ok, thanks DavesZ#3... I'll look further into it with Nissan North America
Old Aug 21, 2010 | 10:32 AM
huanandonly
yeah..i know that was the issue with the 2007 Z's slave cylinder recall...that people had to drop off their cars for the whole day for the work to be done... because they had to get inside the tranny. The previous year 2006, it was on the outside...easier to get to.
Old Aug 21, 2010 | 11:18 AM
DavesZ#3's Avatar
DavesZ#3
I think we're thinking of two different pieces. This is the piece I'm thinking you need...
CLICK
Old Aug 21, 2010 | 11:30 AM
huanandonly
so this is the piece that you suspect might be causing the clutch to "stick" half way on the way back out?
Old Aug 21, 2010 | 12:49 PM
terrasmak's Avatar
Contact Fontana Nissan and ask them, why bother with any other dealer if you live in SoCal.
Old Aug 21, 2010 | 01:22 PM
winchman's Avatar
winchman
Despite the fact that the Courtesy Parts page you linked to shows the external cylinder is used on the '03-'09 models, the design was switched to a concentric slave cylinder for the late-'06-'08 models as shown on this page:
http://www.courtesyparts.com/350z-pa...5_778_792.html
The last two figures on that page show the concentric slave cylinder for the later models. Note that they don't show a fork lever and pivot ball, both parts which would be necessary with the external cylinder.
The concentric slave cylinder is mounted around the transmission input shaft housing, between the clutch and the transmission.
Old Aug 21, 2010 | 02:51 PM
huanandonly
winchman, so the needed parts are: 3060A0+A, 3060A0+B, 3060A1+A, 3060A2+B ? is this correct?
Old Aug 22, 2010 | 03:07 AM
winchman's Avatar
winchman
That's the way I see it.
306A0+A and 306A0+B would be used on 11/2006 -07/2008 vehicles with MT A04
306A1+A and 306A2+B would be used on 07/2008 and later vehicles with MT A05 (including '09 Roadsters)
I don't see why you'd need the tube assembly (306A0+B or 306A2+B). There's not much that can go wrong with them, unless you bugger the threads somehow.
Note: The parts list clearly has the incorrect name for the 306A0+B. It should be: 350Z TUBE-CONCENTRIC SLAVE
Old Aug 22, 2010 | 03:41 AM
SE5spd's Avatar
SE5spd
When I hit 35K my slave went out on my 07 ... Took it to the dealer and they covered it under warrenty without any questions or problems, I don't see why they'd be givig you a hard time about it.
Old Aug 22, 2010 | 04:20 PM
huanandonly
Well, it turns out that when i took the Z in yesterday, they couldn't even duplicate the problem.... so guess what?...they didn't even want to touch it. I noticed that the clutch gets half-way stuck once in awhile...when it's cold in the mornings when i first start it. (we're talking maybe about 4 times in the 3 years that I have the car....So my dealership's policy is that if they can't duplicate the exact problem...they're not gonna start ordering parts and breaking anything down on the car.
Old Aug 22, 2010 | 11:38 PM
winchman's Avatar
winchman
I can't blame them for their policy on that. The concentric slave cylinder is an iffy design in my opinion. The piston is large in diameter with a short stroke, and the compact space means the piston itself is pretty short. That's just asking for it to get a little sideways and bind in the bore, which it apparently is doing. Such a problem would be intermittent, unpredictable, and likely temperature related. I'm not surprised at the number of times this problem shows up.
As for a fix, I'd suggest either replacing the cylinder on your own or taking it apart and putting some super-good silicone lubricant on the cylinder (both the inside and outside) on the engine side of the piston.
Since it's a pretty big job just getting to the thing, you'd probably want to replace it rather than try to get away with just putting grease on it.
Old Aug 23, 2010 | 08:33 AM
xzotklr's Avatar
xzotklr
Upgrade to a Wilwood unit!!
http://www.wilwood.com/MasterCylinde...temno=260-1333
Old Aug 23, 2010 | 12:21 PM
huanandonly
thanks for all your help everyone. I'll prolly look into getting a new clutch anyways and swapping that slave cylinder in one shot. If it's not thing....it's another
