My Vk56 Swapped 350z
Old Aug 23, 2010 | 05:25 PM
  #41
BillytheKid's Avatar
BillytheKid
that is one frankenstien of a Z... i love it
Old Aug 23, 2010 | 06:50 PM
  #42
raycs7's Avatar
raycs7
really nice inspiration for a sleeper...
sub for info
Old Aug 23, 2010 | 07:00 PM
  #43
TRYNALIVEPRO's Avatar
TRYNALIVEPRO
very nice, good luck with it
Old Aug 23, 2010 | 11:00 PM
  #44
350XTCz's Avatar
350XTCz
Just full of awesomeness!
Old Aug 24, 2010 | 10:48 AM
  #45
homeboynyc's Avatar
homeboynyc
nicely done.
Old Aug 24, 2010 | 11:36 AM
  #46
nismonian's Avatar
nismonian
pure win!
Old Aug 24, 2010 | 03:05 PM
  #47
Augustus46's Avatar
Augustus46
Wow, that is an awesome. You have a gift. Changing tires and oil is about as far as I get.
Old Aug 24, 2010 | 03:55 PM
  #48
bardabe's Avatar
bardabe
sub for info
lol nothing about this car is sleeper, its just down right ridiculously nice
Old Aug 24, 2010 | 04:15 PM
  #49
bimmertech's Avatar
bimmertech
i'm amazed at the engine placement---very nice.
it looks very close to the wiper linkage, do the wipers still function?
how much room, approximately, did you gain with removing the "pre-firewall"?
Old Aug 24, 2010 | 05:39 PM
  #50
MPD47's Avatar
MPD47
Yep, Wipers still work, I just installed them Saturday night.
IIRC it's somewhere between 6" and 7"
The trans bell housing now sits almost against the firewall (about 1" away) whereas this is how far it sits stock.
Old Aug 24, 2010 | 07:06 PM
  #51
KingBaby's Avatar
KingBaby
Hardest Setting
Hey mister Mike fella more ******* pictures please!
Old Aug 26, 2010 | 07:13 AM
  #52
Tsukuba-Z33's Avatar
Tsukuba-Z33
still locked in to this thread lol. sick project
Old Aug 26, 2010 | 08:11 AM
  #53
fakejojo's Avatar
fakejojo
Amazing work man!
Old Aug 26, 2010 | 11:17 AM
  #54
DaveFunction2ND's Avatar
DaveFunction2ND
Originally Posted by MPD47
2009 Drifting with ClubLoose at Englishtown Raceway Park's Roadcourse
This car was previously owned by a friend of mine (dmoffitt on my350z), it had gone through a few different specs over the years, NA, APS twins, Built NA, and was a basically stock NA motor when I purchased it from him last year. I had been drifting it in Canada with Driftops and in Jersey with ClubLoose last season, and while I had a blast the car really needed more power.
To solve that "power" issue I decided to install a 4,000 mile Nissan 5.6L V8 from a Nissan press car.
I ended up cutting out a large amount of factory heat shielding so that the motor could be pushed back completely against the firewall. The front of the V8 now sits about equal to where the middle cylinders on the V6 where. Really nice Front-Mid engine mounting
As the VK never came with a manual transmission during it's production run, I had to adapt something to it. I've got a few 350z transmissions hanging around so I fastened up an adapter plate, had it machined and was able to use a slightly modified 350z 6 speed with a carbonetics carbon/carbon twin plate clutch assembly.
The ride height has been changed since these photos were shot, the engine was not in the chassis when I snapped these two back in late April.
There was a long debate about bodywork as well, I really was unhappy with having replaced 4 Nismo V2 bumpers the previous season. I desperately wanted something poly and flexible, but couldn't find anything that I liked the style of. Sooo I started looking up 370z parts. It appeared as though things would be a close fit, so I bit the bullet and ordered 370z Nismo bodywork. It's got a bit of a flared 911 RSR type fit to the fenders, which I'd actually like to make a metal template so it looks a bit cleaner, but for now I think it looks pretty cool.
Engine bay is a bit of a mess, something to clean up this winter.
The engine is an incredibly tight fit in the bay. It's really only possible to do plugs in the engine bay. Anything requiring head/cam service MUST be done out of the car. Thankfully it's pretty easy to get in and out just dropping the subframe straight out. I really want to add dry breaks for the fuel and cooling systems this winter, but that's a lot of extra coin to drop right now. I still need to delete the ABS pump/computer and clean up the brake lines (and add an adjustable bias valve in cabin).
Racepak IQ3 digital dashboard, Hydraulic ebrake handle.
I ended up putting a ViPEC V88 ems system in the car, which does NOT link up to the stock gauge cluster, so I swapped it out for a Racepak digital dash solution. Which I really, really, like The hydraulic ebrake is something I started buying parts for last season. I had been running Project MU shoes in the factory mechanical ebrake, which worked REALLY well, however it seemed awkward for me to reach mid drift. I constantly had to adjust it to get the bite point to be the same and generally was not happy with the amount of effort I had to put in to keep it where I liked it. Just wasn't for my driving style. So I created a template for a bracket which I then had digitized and cut for a second set of brakes on the rear spindle as an isolated Hydraulic ebrake system.
Mike @ Innovative Tuning in Buffalo NY did the tuning and helped me with the electronics side of setting up the car. We ran it in on his Mustang Dyno last week:
Dyno Vid:
http://vimeo.com/14260790
Free Revs:
http://vimeo.com/14202573
I can't describe how happy I am with the project (even without having driven it in anger yet). The car sounds pretty insane, and is a decent bit louder than my straight piped M5 was.
The basics of the drivetrain right now are:
Nissan Titan 5.6L V8 (VK56DE, stock internally... for now)
Carbonetics Twin Plate (Carbon/Carbon)
Custom Headers
Nissan 350z Factory 6 Speed (custom shifter, custom adapter plate, modified bell housing)
Driveshaft Shop Aluminum driveshaft
Carbonetics 1.5 way differential
ViPEC V88 EMS
I was having some cooling issues, as the Titan motor generates quite a bit of heat, after trying two off the shelf radiators I ended up having a local friend of mine make me a custom one with two ridiculous fans. The car should never have overheating issues again.
Thought you guys might be interested, I'll post more pics and videos as things progress. I'm hoping to run it in at ClubLoose's Hot Moves @ Englishtown Raceway Park next Saturday if all goes well. I'm dropping the car off in the morning to get the cage work finished (adding new door bars, a-pillar bars, and windshield bar to make it legal for DMCC/Formula D). Still have a few things to sort out (alignment, electrical kill switch, install fire suppression), but it's coming along nicely.
Big thanks to the guys at Innovative Tuning (Buffalo NY) and Dorschel Nissan (Rochester NY) for their support while I was putting together this project. Also big thanks to Dave @ Function Tuned (Dulles, VA) for getting me that Racepak unit overnight when I was in a pinch!
Looks awesome! I haven't seen all the pics put together like that before. Its a racecar did you pull the thermostat out?
Old Aug 26, 2010 | 11:37 AM
  #55
MPD47's Avatar
MPD47
Course I did buddy I'll be down for atleast 100 Drifters of December, maybe an event or two more. Thanks!
Old Aug 26, 2010 | 12:01 PM
  #56
hwcustoms's Avatar
hwcustoms
bada$$
Old Aug 26, 2010 | 09:16 PM
  #57
MPD47's Avatar
MPD47
Quick little street pass after working on some cage updates tonight, before putting it in the trailer.
URL:
http://vimeo.com/14470732
Was the first time driving it really, it rev's out incredibly fast, burns the tires off in 3rd if I let it. I was shifting on the the 2nd of my sequential shift lights just because I was not used to it. (500rpm early or so)
Taking the car to Englishtown Saturday for some drifting with ClubLoose.
Old Aug 27, 2010 | 03:16 AM
  #58
midz350's Avatar
midz350
Old Aug 30, 2010 | 02:45 PM
  #59
citymunky's Avatar
citymunky
That sounds BADASS!!
Old Aug 30, 2010 | 02:48 PM
  #60
MrHannya's Avatar
MrHannya
you sir are a badass
