My Vk56 Swapped 350z
Old Aug 23, 2010 | 05:56 AM
Russ@Z1's Avatar
Russ@Z1
I look forward to seeing this in action.
Old Aug 23, 2010 | 06:18 AM
08panna's Avatar
08panna
your doing it right
Old Aug 23, 2010 | 06:48 AM
djamps's Avatar
djamps
why the low WHP / power drop-off up top? Is that normal?
Old Aug 23, 2010 | 08:29 AM
MPD47's Avatar
MPD47
Thanks everyone, it's been a tough battle to get all the little details sorted out on this.
Originally Posted by KingBaby
cost?
downtime?
I had a lot of the parts already when I started this. But figure:
Custom Headers
Adapter Plate
VK56
Custom Driveshaft (DriveShaftShop Aluminum 5")
Trans/Motor Mounts
ViPEC V88
Racepak IQ3
And you have the minimum cost of my basic setup. Obviously there are a bunch more parts. But I think you can get an idea from that list.
Originally Posted by Z1 Performance
Very cool project
Thanks Adam, I've been following your project as well. Cool stuff for sure
Originally Posted by Adon
Are my eyes deceiving me, maybe photoshop.... or did you really transplant a 370 front end onto the 350 ? you win in life my good sir
Yeah, it's really there.
A few reasons for that. It's a bone stock factory motor other than tuning and headers/exhaust. We know my intake pipe is choking the motor, the IATs are a bit absurd right now, and the pipe is too small. Something I should fix but haven't gotten around too yet as we just got the car started and tuned the other day. It's also on a Mustang dyno which typically reads "lower" numbers than DynoJet's, which is what you see a larger amount of people using for typical dyno runs. Factory rating is 305 hp / 379 ft·lbf (at the crank). It's nothing I'm really concerned about, a few tweaks (cams, intake pipe, throttle body, or a blower) and the problem will be taken care of. Just want to drive it for a bit right now before I worry about screwing around with stuff.
Old Aug 23, 2010 | 10:06 AM
djamps's Avatar
djamps
Cool...I didn't mean to imply low numbers I was speaking mainly of the tq dropoff up top...the restrictions would explain that. Good luck with the build!
Old Aug 23, 2010 | 10:33 AM
SniperHunter's Avatar
SniperHunter
I'm not surprised this worked, actually. Afterall, the 370Z was using 350Z body parts when it was being tested around.
Old Aug 23, 2010 | 10:40 AM
MPD47's Avatar
MPD47
No worries, just felt like giving an explanation. Thanks
Old Aug 23, 2010 | 10:42 AM
Highway Riding's Avatar
Highway Riding
Finally! i posted ur Vimeo vid not too long ago.. Sick setup dude!
Old Aug 23, 2010 | 11:08 AM
adamciya350's Avatar
adamciya350
Dammit...and I was just about to upgrade to 06-08 headlights
awesome build
Old Aug 23, 2010 | 11:14 AM
Guilty1s's Avatar
Guilty1s
And even better a Nismo 370 front end
Old Aug 23, 2010 | 11:30 AM
blue350zed's Avatar
blue350zed
Kudos to you sir. Different than the old LS swap...keepin' it in the Nissan family.
Old Aug 23, 2010 | 12:17 PM
tylerxfire's Avatar
tylerxfire
sweet man..im out by utica not too far away..id love to see this car in action
Old Aug 23, 2010 | 12:19 PM
tylerxfire's Avatar
tylerxfire
what do u do about inspection in ny state? must be throwing codes or something that would not work out...
Old Aug 23, 2010 | 12:40 PM
MPD47's Avatar
MPD47
It's technically just a track car, but I may reg it in Florida so I can drive it on the street occasionally.
Old Aug 23, 2010 | 01:30 PM
tylerxfire's Avatar
tylerxfire
thats what i figured...i beleive u can also do vermont and that is closer to do
Old Aug 23, 2010 | 01:46 PM
MPD47's Avatar
MPD47
I don't own property in VT, so I doubt I can do it there.
Old Aug 23, 2010 | 01:51 PM
220's Avatar
220
I see you are running a custom Brembo set up in the rear; what was involved?
What are you running in the front?
Old Aug 23, 2010 | 02:01 PM
  #38
MPD47's Avatar
MPD47
I have two brake systems in the car. Factory Brembos on all 4 corners, then a second set of brembos in the rear on a custom bracket I made. Those are connected to the hydraulic handbrake in the car on an isolated system.
Old Aug 23, 2010 | 03:17 PM
  #39
JasonZ-YA's Avatar
JasonZ-YA
Dude! great work man! awesome set up for sure!
Keep the pics and updates coming.........big and small as they come..
-J
Old Aug 23, 2010 | 05:09 PM
  #40
tylerxfire's Avatar
tylerxfire
From what ive heard you just need a p.o box and dont even need to live there or own any property...I have to get more info on this myself for future plans if ny state inspection stays the way it is
