03-05 vs 07-08 manual transmissions
Old Aug 26, 2010 | 10:14 AM
JRas's Avatar
JRas
Default 03-05 vs 07-08 manual transmissions
I'm wondering if their are any major differences.
is the 07-08 a stronger transmissions?
can I use a 03-05 transmission on an 07-08 engine, or are the bell housings different?
I have an 07-08 engine and need a transmission, unfortunately I'm having a hard time finding a 07-08 transmission locally. I see 03-05's all day though ( cheaper too )
Thank you
Old Aug 26, 2010 | 10:48 AM
raycs7's Avatar
raycs7
Tranny is not interchangeable as a simple swap.
The bell-housing shape is different.
Starter position is different
CAP sensor position is relocated.
Slave is different but should be no problem.
If you were closer, I have a 07 tranny waiting for a home.
I like the shift better with the new tranny.
I may consider replacing the motor in my 03 with a 08 HR ..
Old Aug 26, 2010 | 12:43 PM
BoomerZ33's Avatar
BoomerZ33
Not sure if there's any major differences between the two except maybe the clutch. Besides the revision and upgraded design of the HR motor the tranny should be relatively the same as the ones mated to the DE.
Old Aug 27, 2010 | 06:30 AM
louie12345's Avatar
louie12345
I have an 08 tranny, too bad you are so far away.
Old Aug 28, 2010 | 03:22 PM
JRas's Avatar
JRas
can always send, pm me
I guess the bell housings are different and the slave cylinder is in the 07-08 transmission?
07ZEKE
Aug 23, 2021 09:15 PM
burglapfd
Dec 6, 2020 01:04 PM
MyZ2Slow
Mid-Atlantic Marketplace
Sep 9, 2015 10:17 PM
