turbo timer install help + gizmo shift light
Old Sep 14, 2010 | 09:49 AM
bbs350z's Avatar
bbs350z
Default turbo timer install help + gizmo shift light
hey guys i have an apexi turbo timer and cant find an install guide for it at all, anybody have one or can tell me what wires go where?
i also have a gizmo shift light that i need as my shiftpoint is higher than the 8k my cluster ends at, can anybody help me out with this too?
appreciate it alot, hate wiring lol
Old Sep 14, 2010 | 10:27 AM
str8dum1's Avatar
str8dum1
there are a few DIY for turbo timers on this forum with wire colors. But its easy enough to look at the service manual as well to double check.
I'm sure you have seen this http://gizzmousa.com/file-copies/Gizzmo-DSII_manual.pdf
you will most likely have to buy the autometer tach adaptor to make it work http://www.autometer.com/cat_accesso...il.aspx?vid=99 unless you tap directly off a coil wire in the engine bay.
or the gizzmo one https://www.shopatron.com/products/p...er=G0903/684.0
again there are quite a few shift light how to's
sherm
Apr 11, 2020 05:21 PM
samansharif
Sep 25, 2015 12:31 PM
