Wheel Hop during Burnouts?
Old Nov 18, 2003 | 01:49 PM
CaLiFoRnIaZ's Avatar
CaLiFoRnIaZ
Default Wheel Hop during Burnouts?
This may be the wrong place to post this but I am sure other people get wild rear wheel hop when doing a burn out, I DO BAD and can't stand it, basically makes it so I cant do a burn out. Does anybody have a solution to this problem????
thxs in advance!
Old Nov 18, 2003 | 01:52 PM
azrael's Avatar
azrael
It's not a poorly designed rear end. That couldn't be further from the truth. Nissan simply didn't design for drag racing.
The Z's IRS (Independent Rear Suspension) is designed for minimal body roll and performance in cornering, etc.. not for burnouts and launches.
Either way, unless you're running drag slicks, you don't need to be doing burnouts anyway. Burnouts actually degrade the performance of regular DOT street tires.
Old Nov 18, 2003 | 01:56 PM
twenzel's Avatar
twenzel
I dont think he was looking for a lecture on his driving habits but the problem can be solved. Maybe a coilover setup would help I dunno.
Old Nov 18, 2003 | 01:58 PM
CaLiFoRnIaZ
Default umm
ok you don't know, thxs!
Old Nov 18, 2003 | 02:04 PM
Z Powered's Avatar
Z Powered
Traction bars...JIC maybe...?
Old Nov 18, 2003 | 02:06 PM
Glasgow Smile's Avatar
Glasgow Smile
dat title
Maybe post this in the suspension forum?
Old Nov 18, 2003 | 02:07 PM
CaLiFoRnIaZ
Default umm
when you burnout can you burn out a 15 foot patch and not get any wheel hop, mine did it the day i got it from the dealer, just worst now with the extra power.......
Old Nov 18, 2003 | 02:35 PM
azrael's Avatar
azrael
yup, you nailed it.. I have no clue what I'm talking about.
just curious... why do you need to lay down a 15 ft patch of rubber?
Old Nov 18, 2003 | 02:49 PM
nigevellie's Avatar
nigevellie
to buy new tires?
Old Nov 18, 2003 | 03:48 PM
CaLiFoRnIaZ
well................because it is fun??......my dad is 62 years old and got a 03 e55 and i tell you.............he likes to burn a 15 foot patch out in our business park...............tires are not my concern, if they go bald buy new ones..........and i didnt say i needed to lay a 15ft patch, its just fun once in awhile goofing around but with the way the car is now, your rear end would fall off before you ever got to 15 feet..............
This is about "if anybody knows how to fix the problem when burning rubber", not why "are you burning rubber".............if nobody has this worry or problem then just don't post a reply......but if someone has constructive ideas to fix my problem, then GREAT I thank you for your help...............-Kevin
Old Nov 18, 2003 | 04:40 PM
CottonWoodz's Avatar
CottonWoodz
Try lowering your PSI in the tires?
Old Nov 18, 2003 | 04:51 PM
zillinois's Avatar
zillinois
Don't let those dumbos get to you guy. Burn outs are ok. Start out with a little roll maybe 5-10 mphs depress the clutch and bring the motor up to 1900-2300 rpms and let out the clutch quickly. The Z suspension does not have leaf springs like old muscle cars so burn outs need a little more finesse. Practice the rolling burn out by bringing up the rpms a little higher each time until you get the desired results. That should eliminate most of the wheel hop. Then once you get the feel of it you should be able to do them from a stop. Please be safe and keep out of traffic when doing this though. Also, make sure your tires are at 35 psi.
Old Nov 18, 2003 | 05:02 PM
35ounces's Avatar
35ounces
03 CS Track 6MT
Drive it like you've gone mad!!!!!!
Check the tire pressure. I slide the rear end around virtually every corner and burnout whenever I feel the need - its the only way to drive!
Old Nov 18, 2003 | 07:05 PM
CaLiFoRnIaZ
I wish that this did fix the problem, but i do beleive it is because it is a cheap suspension in the rear somehow..............aint no way a exotic would wheel hop, camero's, mustangs sometimes, etc will, due to the cost you pay for the vehicle. Trust me I am a very experienced driver, i am 32 years old for crist sake.............anyways thxs........
Old Nov 18, 2003 | 07:33 PM
spazpilot's Avatar
spazpilot
I don't have the wheel hop problem on burn outs.
Old Nov 18, 2003 | 08:39 PM
vfr350's Avatar
vfr350
I get wheel hop bad sometimes, even when I was at the strip. I had an 85 200sx with the independent rear set-up, did the EXACT same thing, with far less power. I just live with it....
Old Nov 18, 2003 | 09:02 PM
Scanman's Avatar
Scanman
I'm very surprised this thread didnt get the response it deserved.
I mean come on folks, half the fun of owning a powerfull car is being able to do a decent burn-out without looking like a jackass doing it.
Nothing worse than dumping the clutch and "boom boom boom"....
massive wheel hop, real impressive for a hot car.
Come on guys, were's the suspension problem?
And dont tell me to buy a Camaro. Already had one, 2000 z28. Burnout par exellance'.
Old Nov 18, 2003 | 09:56 PM
ares's Avatar
ares
Veteran
depends on the surface whether it show up, also maybe temp, and just luck of the draw.
however as for the cure. bushings, suspension bushing, engine mount bushings, everything, need to be tighter. a new suspension can help, different tires(he is right, the stock tread is designed to not "slip" but instead grab even after traction is lost. )
none the less, you shouldnt do it but thats where youd start to solve it. I dont think half that stuff is even available to buy tho.
Old Nov 19, 2003 | 01:30 AM
zillinois's Avatar
zillinois
No offense meant California. I just haven't had any problem with wheel hop at the track or on the street. I've done 13 runs in a row at a quarter mile track with launches between 1800-3500 rpm with zero wheel hop.
I'm not sure how to address the charge of cheap suspension. What do you want from your suspension is a more productive approach. The suspension performs admirably at the track for a stock car. I think that rules out the possiblity of it being cheap. Ford Fiestas have cheap suspension. The reason an "exotic" won't wheel hop is because the suspensions, until recently, were built solely with cornering and traction in mind. They were stiff, like riding in an ox cart. If you really want to eliminate wheel hop put stiffer springs and shock/struts combo with traction/camber bars. Of course without electronically adjustable suspension or some other way of easing up the stiffness you will lose your spleen over every bump. So its a trade off. Softer suspension equals softer ride and less performance. Also, a typical exotic costs $100,000 dollars more than our cars. An exotic car is not a good reference point when trying to determine whether your suspension is cheap or not.
If you don't want to do that, here is an old muscle car trick. Make or find a metal bracket that will hold your favorite 1 gallon container of liquid bleach. Get a fish tank style water pump, rubber hose, electric switch and some zip ties. Find a mounting point for the bracket, mount a valve through the plastic cap of the bleach container, connect the hose from the valve to the water pump, then run the hose lines from the pump to the tires. With zip ties, aim the end of the hose where the rubber meets the road. Then hook up the switch somewhere on the inside of your car and run it to the pump. When you want to do burnouts just press the switch and let 'em rip. You will get big impressive blue smoky burnouts! Do not blame me if anything bad happens though ok?
Old Nov 19, 2003 | 09:07 AM
azrael's Avatar
azrael
I didn't mean to come off like a jackass. If you really want to do burnouts, I suppose that's your perogative. I don't think they're all that impressive, but that's just me. Most people I've seen doing burnouts came off as idiots trying to put off a show.. but I guess it's not my place to judge you.
The real problem I have with what you're saying is that you're claiming the car has a "cheap suspension" just because it's not made for burnouts. I've seen absolutely no evidence to suggest that the Z's suspension is cheap. It's just not designed for this application. The leaf spring setup you see on Corvettes helps eliminate the wheel hop you seeing. However, the people who track their Vettes end up going with a fully independent coil-over-shock setup like ours (but stiffer). There is a trade-off there. Nissan chose a suspension better for cornering, rather than launches and burnouts. Realistically, if burnouts and drag racing are your cup of tea, the Z might not have been the best choice... but if you want to spend some cash, you can adapt the suspension for whatever goals you choose.
Anyway, sorry to be rude. Good luck correcting your wheel hop issue.
