VQ37 Block swap...
Old Dec 1, 2010 | 10:57 PM
me1109's Avatar
me1109
Question VQ37 Block swap...
So I was throwing this idea around with a couple guys at my shop today:
VQ35de Heads
VQ37 Short Block
Pathfinder Timing chain cover
VQ35VHR oil pan
Any one done this?
Old Dec 2, 2010 | 04:28 AM
10-E-C-350Z's Avatar
10-E-C-350Z
Old Dec 2, 2010 | 04:51 AM
sradenton's Avatar
sradenton
I read some were, about someone doing that with a HR block
Old Dec 2, 2010 | 05:07 AM
10-E-C-350Z
https://my350z.com/forum/na-builds/3...-build-up.html <-- this guy?
Old Dec 3, 2010 | 09:22 AM
me1109's Avatar
me1109
Originally Posted by 10-E-C-350Z
HAHA that was awesome!
But i was just looking for something interesting to do... I am going to be rebuilding my motor, I have my Cosworth 11:! sitting in my closet and it made since while the motor was torn down to do as much to it whilst it was down...
I have never seen the top of a VQ37 block but I assume it is not toooo much different....
I found a picture of a vq37 and a vq35 Just to compare what they look like...
Attached Thumbnails VQ37 Block swap...-4438329879_01e41abeb7.jpg   VQ37 Block swap...-679128603_y2bx5-m.jpg
Old Dec 3, 2010 | 09:25 AM
me1109's Avatar
me1109
oops vq 35 pic failed...
Old Dec 6, 2010 | 12:33 AM
me1109's Avatar
me1109
Exclamation
why is there a giant duck at the old sub base in germany?!
Old Dec 6, 2010 | 01:19 AM
10-E-C-350Z
Because it makes about as much sense as your proposal.
Old Dec 6, 2010 | 02:01 PM
terrasmak's Avatar
I was really thinking about VQ40 (xterra) with 35 heads
Old Dec 6, 2010 | 05:05 PM
bbs350z's Avatar
bbs350z
the 37 block is very different from the 35 block. even the swap itself would not be worth the hassle. its alot more complicated than just a swap/ecu/harness. youd be better off stroking your current block.
Old Dec 6, 2010 | 06:15 PM
fabre80's Avatar
fabre80
What he said.
Old Dec 6, 2010 | 06:28 PM
Quamen's Avatar
Quamen
I agree. You could turn your VQ35 into a high revving VQ38 for significantly cheaper than swapping the VQ37 block. Waste of money IMO.
Old Apr 18, 2011 | 01:41 PM
jr429's Avatar
jr429
What's a VQ38?
Old Apr 18, 2011 | 01:49 PM
Russ@Z1's Avatar
Russ@Z1
Originally Posted by jr429
What's a VQ38?
a stroked vq35.
Old Apr 18, 2011 | 01:53 PM
jr429's Avatar
jr429
Cool... So has anyone tried the block swap? What are the differences in the blocks? Bore + stroke or just bore?
Old Apr 18, 2011 | 11:57 PM
terrasmak's Avatar
I don't know if the DE heads will work, but the Grand Am 370Z is running 3.5HR heads on a 3.7.
Also to run an HR block you will need the newer trans, only half of the bolts will line up with the older trans.
Old Apr 26, 2011 | 01:52 PM
PeterSellers's Avatar
PeterSellers
That's only true for the 37 vs. the DE blocks. The HR and VHR blocks are more similar to each other than the HR and DE blocks.
I'm guessing that it wouldn't be too much hassle to put an HR head onto a VHR block, but I haven't done it myself so I could be wrong there.
Old Apr 26, 2011 | 03:28 PM
zheiland's Avatar
zheiland
Default 3.5 block 3.7 crankshaft.
Hey,I was thinking why not just use the crank
out of the 3.7 with the 3.5 block.Maybe the lower
part of the block might have to be machined to
make it work.And maybe the rods from the 3.7
with custom pistons?I was only thinking!!!Maybe.
sherm
Apr 11, 2020 05:21 PM
Workshop12
Mar 23, 2020 01:45 PM
foxsmp26
Sep 25, 2015 09:48 AM
PureR3d
Sep 10, 2015 06:23 PM
