Error Codes P0171, P0301 & P0507. Help please?
Old Jan 14, 2011 | 03:01 PM
BlackJack07's Avatar
BlackJack07
Default Error Codes P0171, P0301 & P0507. Help please?
I went and had the codes read at AutoZone and these 3 codes showed up. Ive tried the seafoam the first time that the check engine light came on because only one code showed up and the guy recommended cleaning the fuel system to see if it helps. Well, it hasn't helped and now I have gotten these 3 codes. I was thinking of doing the seafoam again but this time try to do 1/3 through the vacuum hose and the rest in the tank rather then the whole bottle into the gas tank like the first time. Does anybody think that it would make a difference? And should I try this first before anything else? I'm hoping that it's just the fuel system that has crud built up and that this can just clean it but I'm afraid that it's most likely more than that. If anybody has any suggestions or any experience with this then any recommendations would be considered and I would really appreciate any help. Thanks
Old Jan 15, 2011 | 04:04 PM
BlackJack07
Cleaned the MAF and reset the CEL but it came back within the next few minutes of driving. Anybody have any suggestions? Maybe replace the spark plugs or coil packs will help? Looking for some good ideas.
Old Jan 20, 2011 | 05:18 PM
shiftdrift06's Avatar
shiftdrift06
WHat are the codes for?
Old Jan 21, 2011 | 08:21 AM
Zazz93's Avatar
Zazz93
Check for intake tract air leaks and bad injector. Wouldn't hurt to change that plug either (Cyl #1).
P0171 Fuel Injection Lean code B1
P0507 ISC (Idle Speed Control) - Erratic Idle will trigger this one
P0301 Misfire in cylinder 1
etkms
Jun 19, 2022 06:30 PM
aarrgghh
May 1, 2022 11:04 AM
350Z Project X
Oct 17, 2015 05:16 PM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
