Problems at a stop
Old Jan 24, 2011 | 08:49 AM
redzblackh's Avatar
redzblackh
Default Problems at a stop
My car was having problems goin into 1st and 2nd for a little while when I was downshifting, now when I'm parked I have to force it into 1st and reverse. WTF???
I have an HR and I just put a new JWT clutch and flywheel in about 700 miles ago
Old Jan 24, 2011 | 09:22 AM
bmccann101's Avatar
bmccann101
Default clutch
sounds like air in your fluid.. bring it back, get it re-bled.
Old Jan 24, 2011 | 09:23 AM
bmccann101's Avatar
bmccann101
pump your pedal a fwe times next time you ahve the issue.. watch it work a bit better.. im sure this is all it is.. if you wait to repair it, it may cost you your new clutch tho.
Old Jan 24, 2011 | 11:52 AM
I think we just found the problem.
Old Jan 24, 2011 | 01:23 PM
terrasmak's Avatar
Bleed the clutch as mentioned it may not be getting full movement. Also the trans is harder to shift when cold, its been cold out in most areas.
Old Jan 24, 2011 | 06:46 PM
redzblackh's Avatar
redzblackh
What's wrong with JWT?
Old Jan 25, 2011 | 09:45 AM
kramykram's Avatar
kramykram
+1
Old Jan 25, 2011 | 10:48 AM
redzblackh's Avatar
redzblackh
how can you agree but know explain y?
Old Jan 25, 2011 | 11:34 AM
red350track's Avatar
red350track
im having the same problem with the upgraded slave cylinder on the southbend kit with the southbend flywheel if you find out the reason let me know.
Old Jan 26, 2011 | 11:43 AM
redzblackh's Avatar
redzblackh
still no reply about why buying JWT caused the problem,
Old Jan 27, 2011 | 03:17 PM
red350track
did you buy the upgraded slave cylinder from custompartz?
Old Jan 28, 2011 | 07:02 AM
redzblackh's Avatar
redzblackh
no, didnt know about that. people are telling me that i should adjust the engagement. that maybe its off and not dissengaging causing the gears to not line up right
Old Jan 28, 2011 | 07:05 AM
06g35meister's Avatar
06g35meister
Air in clutch fluid.
JWT is an amazing clutch, dont worry thats not your problem.
Old Jan 28, 2011 | 09:42 AM
redzblackh's Avatar
redzblackh
ok well im gonna have somebody show me how to bleed the clutch line this afternoon. ill post what happens
Old Jan 28, 2011 | 04:32 PM
ZSpeedPerformance's Avatar
ZSpeedPerformance
Vendor - Former Vendor
700 miles is a long time for the slave to last with the JWT kit, Normally the stock slave blows out within 500 miles.
I would put my money on your slave is getting ready to leave you sitting.
Old Jan 28, 2011 | 10:22 PM
redzblackh's Avatar
redzblackh
How would I be able to tell if my slave is the problem or when it goes? How do I get one of yours if it's not on your site?
Wait a sec, isn't this the same one red350track has? If he has this SCS that you say will fix the problem how come he has this problem?
Old Jan 29, 2011 | 05:07 AM
ZSpeedPerformance
Here for the slave
"CSC" And we do not know what the problem with redtrack350's clutch is yet.
I believe it is install error or not bled properly or simply out of adjustment at the pedal. There are dozens and dozens of these kits out in use with all kinds of different clutches that work perfectly.
Old Jan 29, 2011 | 06:06 AM
redzblackh's Avatar
redzblackh
wow dude, thats expensive, especially since i just bought a clutch, flywheel, and had them installed, and ill have to have this installed... i think ill just deal with it
Old Jan 29, 2011 | 06:38 AM
ZSpeedPerformance
Not really expensive, Had you replaced it when you did your clutch as recommended it would have been a lot cheaper than what you are about to do now.
If you continue to drive with the clutch dragging you will ruin your transmission.
Also, it will leave you sitting with no clutch pressure at all shortly, That I guarantee
I have no idea why everyone is buying this JWT kit that blows the slave out within 500 miles
Old Jan 29, 2011 | 09:20 AM
red350track
i recommend you get one, due to the fact that if you don't, your going to keep blowing the stock slave cylinders fast. Joe is right its highly unlikely that i got a bad slave, its either install error or maybe i got a defective pressure plate? Who knows i will keep everyone updated.
