Quaife lsd install help
Old Jan 31, 2011 | 09:22 PM
crtan77's Avatar
crtan77
Default Quaife lsd install help
hello all,
i just installed my lsd and i was wondering, after the install, how hard will it be to turn the ring gear? I marked everything before uninstalling it and I don't think i made a mistake on what parts go on which side.. i can barely turn the ring gear with wrench. Is that normal? or did I do something wrong? I have a base model and everyone in the forums say that it just drops right in.
Could it be that the bearings be binding somewhere? Maybe a mistake in putting the lsd in?
thanks
chris..
Old Jan 31, 2011 | 09:54 PM
AngelsVQ's Avatar
AngelsVQ
should spin relitivley freely. pull it back out and make sure there is no debrie in the way.
by the way would you say its as hard as in this video at 2:45 min. or harder?
http://www.youtube.com/watch?v=LObfe...eature=related
Old Feb 1, 2011 | 05:32 AM
crtan77's Avatar
crtan77
Thanks AngelsVQ,
It actually takes more effort than that video. I'll pull it apart and see if something is in the way like you said. I spoke to AcidJake75 and he said that it should be a bit tight but if it spins both stubs, then you should be okay. I'll double check everything today and re-install it. See if that helps..
Thanks
Chris..
Old Feb 1, 2011 | 05:56 AM
AcidJake75's Avatar
AcidJake75
Living in 350Z
yep - just did my buddies...big +1 on that Vid AngelsVQ...backlash (and using gear marker is a plus)
Just make sure neither the stubs or the flange is on the ground or else it will super hard to turn.. I hope thats all your doing - should be PnP....but then again - we all run into lil snags here and there.
Im in for results...let us know OP..
Old Feb 1, 2011 | 12:35 PM
crtan77's Avatar
crtan77
So for my lunch hour today, Took apart the lsd. Nothing seems to be blocking the pinion or the ring gear. I put back the lsd and the shims. Tested and it spun freely. I put back the bearing caps that hold the lsd in the pumpkin. Without torquing em down i spun the output shafts and the lsd spun freely.
I then torqued them down to service manual specs and i find that they are hard to turn once again. So now I guess its due to the new bearing I just put on. Thus I'll just install the lsd later tonight and see what happens. I checked the backlash and the contact seems fine so i would assume that i installed it correctly.
Thanks again everyone for your help. I'll let you know tomorrow how it turns out.
Thanks everyone for your help.
Old Feb 1, 2011 | 12:37 PM
AcidJake75's Avatar
AcidJake75
Living in 350Z
HELL YA!! dude - your gonna be ALL SMILES when you get on it.. Nice job!
Old Feb 1, 2011 | 01:26 PM
AngelsVQ's Avatar
AngelsVQ
i want smiles! im just waiting on my oil to get here! should be here thursday. i got the carbonetics 2 way lsd.
Old Feb 1, 2011 | 01:57 PM
AcidJake75's Avatar
AcidJake75
Living in 350Z
^^^hell ya...your gonna love that tire scrub..
Old Feb 1, 2011 | 10:55 PM
AngelsVQ's Avatar
AngelsVQ
tire scrub i don't mind the inconvenience, i bought this car to drift it, not not for a dd, i have my dd on tha side. might not be balling but its a dd.
Old Feb 4, 2011 | 10:32 AM
G3po's Avatar
G3po
Default Quaife
Tire scrub? I've two of these ,in DDs and actions is like stock till you need it. , no jerking or scrubbing. Much luv for the Quaife.
Old Feb 6, 2011 | 11:45 AM
AngelsVQ's Avatar
AngelsVQ
i just put mine in yesterday, then went drifting for 30 min. f ing amazing... and there is no noise at all
Old Feb 7, 2011 | 07:38 AM
crtan77's Avatar
crtan77
Hello All,
thanks for the help. i did put in my lsd on SAT and its definitely worth the money... i didn't notice any noises from the rear end.. but then again, maybe I was in awe on how the car now behaves.. wow. thanks again...
Old Feb 10, 2011 | 03:22 PM
ian99rt's Avatar
ian99rt
Originally Posted by crtan77
Hello All,
I can't get my tax return fast enough to get mine!!!
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
