Valve covers w/ replaceble seals. Part 2
Old Jan 21, 2012 | 08:16 PM
JaE35z's Avatar
JaE35z
Here are the instructions on how to repair your oem valve covers
http://yhst-13387653796039.stores.ya...nivqvacor.html
the gaskets are only like 60 dollars from r&d, a much cheaper option than using l-fab. They quoted me a ridiculous price
Old Jan 21, 2012 | 08:26 PM
johndoesdamage's Avatar
johndoesdamage
Where on there site do you order them? Thanks a lot
Old Jan 21, 2012 | 08:50 PM
johndoesdamage
Nvmnd I searched more and found out they're on our forums so I guess you order through PayPal? Anyone confirm those seals from a maxima fit our valve covers?
Old Jan 21, 2012 | 08:59 PM
JaE35z's Avatar
JaE35z
Send r&d factory a private msg
Old Mar 12, 2012 | 08:03 PM
blAk mAx's Avatar
blAk mAx
Originally Posted by Andrei
They are from a 2000-2001 Maxima. I remove the oil baffle and wasn't suppose to so that could be the reason. I went by the original pics that I saw that shop post.
these ?
http://www.autohausaz.com/search/pro...%20Tube%20Seal
Old Jun 4, 2013 | 04:28 AM
quanttrom's Avatar
quanttrom
any updates on this?
I would be really interested in getting one of those damaged seals shipped to me. I am wondering if I can talk my friend who works for a large part supplier into rummaging through some seals in their warehouse and finding the right one.
Old Jul 19, 2013 | 12:55 PM
Andrei's Avatar
Andrei
I keep getting questions about this so I'll update. I found some other seals that fit in the flange made by Ishino. They will slip over the spark plug tubes of a VQ since it's very close to the same inside diameter, but I do not know if they would eventually tear because they are stretched out too far but I think it should be fine. I do not have a dial caliper to measure ID. It's a spring loaded seal around the tubes like stock ones so it might not tear.
Ishino Spark Plug Seal : Amazon.com : Automotive Ishino Spark Plug Seal : Amazon.com : Automotive
Old Aug 5, 2013 | 06:05 AM
Z33Garage's Avatar
Z33Garage
Anyone know if this kit works?
Found cyl #6 has this issue now. Makes me want to choke an engineer...
Also why the hell do we drill though the baffle plate?? doesn't make sense. Unless the grommets they give you arent 350z grommets but some other ones that "fit with mods". That's fine but they should say that....
I wonder if this product works without having to drill...
Old Aug 5, 2013 | 12:31 PM
suprasam's Avatar
suprasam
You drill out the plate because you won't be able to remove the seals otherwise. They placed in the valvecover then the baffle plate is glued to the valve cover
Old Aug 5, 2013 | 12:35 PM
Z33Garage's Avatar
Z33Garage
Damn I just connected the damn dots. Would it have killed nissan to just have produced these with wider diameters in the baffles for grommet removal...
I will order a grommet from a maxima and see if it fits. ( I hope the thread posts are correct)
BOATS N HOES
Lighting
Oct 13, 2015 09:07 AM
Brantwilliams13
Sep 16, 2015 05:03 AM
roadmax
Sep 12, 2015 05:55 PM
ddegrande21
Sep 6, 2015 11:15 AM
