Nissan CAN Speed Delimiter, Alter speedsignal
Old Feb 11, 2011 | 08:12 AM
SurraTT's Avatar
SurraTT
Default Nissan CAN Speed Delimiter, Alter speedsignal
Well I came across this yesterday
http://www.ncs-systems.com/prod/1457
Has anyone ever seen this?
Im interested to see if it could help solve the cruise control problem when rear end gears are changed. Or when a ecu swap is done and their is only 1 speed signal (from the gauge cluster to the ecu).
If This box, or the company can make a box , that will Intercept the speed signal from the gauge cluster, duplicate that speed and send it as a output over can to the ecu as the 2ed speed signal, so they would always match.
This could fix cruise control problems that are due to the 2ed speed signal not being correct or not being there at all.
This is the ONLY thing i can find that has anything to do with speed signal over CAN, i emailed dakotadigital they said they have nothing for can systems.
Thoughts???
Old Feb 11, 2011 | 07:27 PM
SurraTT's Avatar
SurraTT
Almost 300 views and no one has any thoughts???
Is this in the wrong section?? whats going on here....
Old Feb 14, 2011 | 06:35 AM
kramykram's Avatar
kramykram
no our cars go faster than what that says anyways. i don't think its going to help with cruise control either.
Old Feb 14, 2011 | 03:48 PM
SurraTT's Avatar
SurraTT
I know, i never said i wanted to use it to remove the speed limiter.
This is the only module ive seen that can alter your speed signal over can lines. If they could alter this module or make a new one that copied the speed signal from the gauge cluster, and sent it to the ecu as the signal from the abs/tcm, then it would fix cruise control issues on swapped gear's and ecu swaps.
I posted to see if anyone had ever heard of or seen this, or knew of another like device that can alter speed signals over can lines. Not getting much feedback tho.
sales@czp
Sep 23, 2019 03:30 PM
ablaine
Nov 29, 2016 10:13 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
