NA V6 discussion
Old Nov 27, 2003 | 01:19 PM
Enron Exec's Avatar
Enron Exec
Default NA V6 discussion
The December issue of Car and Driver has a short article on the probable new NSX. There is alot of speculation within that article, but lets just assume a few things to be certain. It will be a V6, at least 3.5 liters, and at least 350 hp. My question is, what does the VQ35 need internally to accomplish that kind of NA output. Im no gear head, so here are my guesses. Lighter, stronger, and balanced connecting rods and pistons. Increase to ~11.5:1 compression. Maybe an increase in bore and a shorter stroke. Lighter pulleys, clutch, and flywheel? What else do we need? Please list even the smallest of details you would recommend to build the ultimate NA VQ35.
Old Nov 27, 2003 | 01:34 PM
azrael's Avatar
azrael
if you believe the ~300 RWHP dynos we've heard about, then this has already been achieved. No need for replacing the rods/pistons/crank.
I believe it was just bolt-ons plus cams and ECU. Hitting 350 crank HP shouldn't be too difficult, but it won't be too easy to go much beyond that.
Old Nov 27, 2003 | 03:03 PM
toykilla's Avatar
toykilla
high compression would do it. but that would be just as expensive as throwing on a supercharger and much more complicated and more of a chance to screw up the engine
Old Nov 28, 2003 | 01:42 PM
g356gear's Avatar
g356gear
Granted it would be expensive......but why would there be more of a chance to screw up the engine????? Do you think FI on an engine designed for NA power wouldn't have more of a chance to go bad???
Old Nov 28, 2003 | 07:18 PM
Enron Exec's Avatar
Enron Exec
So has anyone had experience with aftermarket high compression and/or lighter pistons on the 350Z? On any VQ for that matter?
Glenn350zHR
Drivetrain
Nov 30, 2015 08:21 AM
