Cosworth Oil Pan Baffle Oil Control Baffle Install Kit
Old Mar 22, 2011 | 02:04 AM
mw9's Avatar
mw9
Default Cosworth Oil Pan Baffle Oil Control Baffle Install Kit
Has anyone tried this, just found out about it in this article.
http://www.motoiq.com/magazine_artic...st-3-days.aspx
http://cosworthusa.com/store/pc/view...&idproduct=740
Attached Thumbnails Cosworth Oil Pan Baffle Oil Control Baffle Install Kit-vqbafweb1_239_general.jpg
Old Mar 22, 2011 | 05:31 AM
rcdash's Avatar
rcdash
Nice find. Interesting that 2003-2004 cars require special parts for install - didn't know the oil pan was different the first couple years? I don't know if this will work with oil pan spacers - looks like it is designed to wedge into the upper oil pan?
Looks like Injected Performance sells it (at a good price too) - maybe they will chime in:
http://www.injectedperformance.com/c...for350zg35.htm
Old Mar 22, 2011 | 08:17 AM
JDMStanced's Avatar
JDMStanced
Cosworth also have this type. http://thmotorsports.com/cosworth/co.../i-290345.aspx
Old Mar 22, 2011 | 07:24 PM
Fixxxercask's Avatar
Fixxxercask
That's interesting. That seems like a cheaper solution than buying a baffled oil pan. I have an APS baffled pan, but I just installed an oil cooler and because of the size of the oil pan my oil lines are practically sitting on my sway bar. Makes me nervous. I would heavily consider buying this. Good find.
Old Mar 22, 2011 | 08:25 PM
Kwame's Avatar
Kwame
Originally Posted by JDMStanced
That's the same product as above but for another motor, not a VQ.
Old Mar 22, 2011 | 08:43 PM
JDMStanced's Avatar
JDMStanced
^^can you explain how cosworth baffle kit is designed to work, and how it's installed?
Old Mar 22, 2011 | 08:46 PM
Kwame's Avatar
Kwame
Honestly, No. I've ordered one for my car and it's supposed to be arriving this week. We'll see if it does.
Old Mar 22, 2011 | 11:14 PM
terrasmak's Avatar
Post details when you get it please !!!!!!!
Old Apr 2, 2011 | 01:55 PM
Kwame's Avatar
Kwame
I think the pictures explain it all...
Before:
After:
Non-Revup Install kit... Obviously just spaces the oil pan
Old Apr 2, 2011 | 08:18 PM
JDMStanced's Avatar
JDMStanced
i was expecting to see more 'doors' in the center rather than on the side.
Does it do a good job on keeping the oil in place when turning? looks like it does the job when accelerating though...idk..i'm a noob.
Old Apr 2, 2011 | 09:10 PM
halfrice's Avatar
halfrice
do they make one for the rev up engine?
Old Apr 2, 2011 | 10:06 PM
Flo-ridaZ33's Avatar
Flo-ridaZ33
Hey Kwame... is there a rebuild for the rubber "doors" in the event they get worn and destroyed? I'm just thinking of the long term effect of having those things in hot oil.
Old Apr 2, 2011 | 11:10 PM
Kwame's Avatar
Kwame
Theoretically during turning the oil will still be in the oil pan and near the oil pump but just on the sides. This prevents the oil from retreating into the back of the upper oil pan opposite the oil pump.
Old Apr 2, 2011 | 11:11 PM
Kwame's Avatar
Kwame
You can use the same oil control baffle for a revup. You just would not need the install kit as far as I know.
Old Apr 2, 2011 | 11:14 PM
Kwame's Avatar
Kwame
As far as I know there isn't. Honestly it would take a very long time before you see any type of disintegration and at that point you might as well purchase a whole new baffle as it's relatively cheap.
Old Apr 3, 2011 | 06:33 AM
JDMStanced's Avatar
JDMStanced
The description of this kit says that only 03-04 needs the spacer kit. i have 05 so i may be good to go w/o it
Old Apr 7, 2011 | 09:51 PM
MR RIZK's Avatar
MR RIZK
my hks sump has the baffle plate as shown below. Would it be worth while to run both the cosworth and hks or would it hamper the oil flow too much. With both installed it will box in the oil where the pickup is.
Old Apr 8, 2011 | 11:29 AM
rcdash's Avatar
rcdash
Would this work with the JWT spacer? I don't understand how it is secured exactly.
Old Apr 8, 2011 | 05:26 PM
JDMStanced's Avatar
JDMStanced
what does that baffle plate at the top do?
Old Apr 8, 2011 | 05:45 PM
SpoilsofWar's Avatar
SpoilsofWar
+1, Kwame, can you chime in here? I'm using an AAM spacer.
I see the 3 holes on the side that faces the lower oil pan that look like they're for securing the baffle, but dont exactly see what they secure it to...
