What is on the inside of my oil cap??
Old Apr 1, 2011 | 10:23 AM
can'tZme's Avatar
can'tZme
Default What is on the inside of my oil cap??
I went to change out my OEM oil cap with my new NISMO cap and I noticed the inside of it looked like this:
It smells like oil but it's thicker than oil. What could be causing this?
Old Apr 1, 2011 | 10:45 AM
sullys350z's Avatar
sullys350z
Coolant will turn oil that color. When you opened the oil cap, did white steam come out?
Old Apr 1, 2011 | 11:01 AM
can'tZme's Avatar
can'tZme
No, the car has been off all day (6 hours)
Old Apr 1, 2011 | 11:42 AM
akdnj88's Avatar
akdnj88
You have coolant in your engine. It's safe to assume your head gasket is done.
Old Apr 1, 2011 | 11:46 AM
can'tZme's Avatar
can'tZme
Wouldn't I see some drivability problems or some white smoke?
Old Apr 1, 2011 | 12:07 PM
ALO8's Avatar
ALO8
yes from my experience, coolant and oil mix give you milky lookin oil. No signs needed such as white smoke or sputtering etc etc. they will come next if they you havent seen sympthoms eventually
Old Apr 1, 2011 | 12:26 PM
can'tZme's Avatar
can'tZme
Hmm maybe it's time for a motor build.
Old Apr 1, 2011 | 12:43 PM
diablox1's Avatar
diablox1
dont wait for heavy white smoke or the other tell tale signs. replace your head gasket ASAP before you really fuuck up your engine, or like you said, do a sick motor build.
Old Apr 1, 2011 | 01:06 PM
cubs4worldseris's Avatar
cubs4worldseris
you sir, have a blown head gasket.
congrats!
Old Apr 1, 2011 | 01:19 PM
97supratt's Avatar
97supratt
Old Apr 1, 2011 | 01:23 PM
can'tZme's Avatar
can'tZme
What about condensation build up in the valve covers? It's been raining a lot here lately and the humidity had been high. The garage it stays in is kind of damp all the time. Also, the car doesn't get drove much. Maybe 20 minutes a day. To and from work. I don't have this color oil on the dipstick, just on the cap.
Old Apr 1, 2011 | 01:33 PM
Yes that would be water.
Old Apr 1, 2011 | 03:02 PM
AJCaron12's Avatar
AJCaron12
OP, I do not believe that this is a head gasket problem at all. It is condensation. Almost every oil cap I remove every day looks like that on the underside, it's normal.
Old Apr 1, 2011 | 03:05 PM
can'tZme's Avatar
can'tZme
That's what I was thinking. If I had oil in my crank case then I would have a problem. After I left work today I drove it around for about 30 minutes hard and when I got home all the milky oil was almost gone off the cap.
Old Apr 1, 2011 | 03:09 PM
AJCaron12's Avatar
AJCaron12
You're ok, I wouldn't worry.
Old Apr 1, 2011 | 03:14 PM
racerx300zx's Avatar
racerx300zx
Can also occur if you have a short drive to work. Still worth a check to make sure compression isn't out, but I've seen a couple cars with the same gunk under the cap that haven't had any issues.
Old Apr 1, 2011 | 03:30 PM
can'tZme's Avatar
can'tZme
Yeah I have like a 5 minute drive to work.
Old Apr 1, 2011 | 03:41 PM
ImWeeZzel's Avatar
ImWeeZzel
the oil cap on my car got like that last time I took a water hose to my engine. Check the dip stick, if its not milky you'll be alrite. like everyone else mentioned it could be condensation.
Old Apr 1, 2011 | 04:49 PM
Sickboy101's Avatar
Sickboy101
Did someone order a Guinness?
Old Apr 2, 2011 | 03:26 PM
bailey bill's Avatar
bailey bill
Right answer.
